I saw that my subtitle is not sync with voice. But i have 500 of them. So can i edit them all at once. Like drag and drop folder/multiple files and then say like "shift subtitle xy miliseconds".
I mean with software. No command lines pls.
Thank you very much.
	Use subtitle edit/tools/batch convert/offset time codes and check that option and drag the folder of subs to the above window and convert. I think,therefore i am a hamster.
	Hey, sorry for my late answer. I could test only now.
 How do i know, what timecode the subtitle need to be to match the video? Because i tried default and another and it dies not work.
 But what does timecode actually have to do with wrong subtitle sync ?
 Edit: Ahh, i did not see the settings pop up only if you click on the words. if you click on the box to check it, it will not show up settings, lol. I did first try to change timecode, lol.
 But it worked now.Last edited by Platos; 2nd May 2023 at 17:02.
  Shift times of multiple .srt files at once with the same time length givenBy rby03 in forum SubtitleReplies: 3Last Post: 31st Mar 2023, 19:58
  Change start time in Subtitle EditBy loninappleton in forum SubtitleReplies: 3Last Post: 20th Jan 2023, 02:27
  Subtitle Edit time shifting issueBy vid100 in forum SubtitleReplies: 3Last Post: 7th May 2020, 20:20
  Multiple replace with Subtitle EditBy [ss]vegeta in forum SubtitleReplies: 4Last Post: 1st Mar 2020, 05:20
  Subtitle Edit multiple lines: how to?By lollozip in forum SubtitleReplies: 1Last Post: 15th Jan 2019, 15:58
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
