I have a 29.97 fps drop frame timeline in Premiere.
It's an old Premiere CS6 that doesn't have the caption-making feature, and my question is about EDL to SRT conversion anyway.
I cut a black video to subtitle breaks and export this track only as a drop frame EDL, so I get subtitle timings in the HH:MM:SS:FF (frames) format.
Then I import the EDL into Subtitle Edit and export it as an SRT.
I test the SRT in Media Player Classic and I see that 2/3 of the SRT timings are 1—2 frames early.
Adjusting wrong timings manually to the player's timecode won't work because a) come on, and b) I tried it, and now most of the adjusted timings are 1 frame late.
Mismatch of 1—2 frames wouldn't matter much in subtitles for one talking head with no cuts. But in my video, I have several talking heads, and I try to time my subtitles to cuts, and the mismatch is noticeable.
The SRT format timing is precise down to a thousandth of a second. Why do I get 1—2 frame mismatches?
Did you use the General Settings in SE to your 29.97? The default is 23 fps. I use 25 fps on my Britsh drama subs.
I think the features in the General settings change things. I've had to experiment with that.
Fixing line splits on an SRT in Subtitle Edit
By loninappleton in forum SubtitleReplies: 1Last Post: 13th Jan 2022, 19:12 -
Two subtitle lines at the same time with different timings (SRT file)
By yaridovic in forum Newbie / General discussionsReplies: 4Last Post: 7th Sep 2021, 05:26 -
Trouble using subtitle edit with srt and video residing on local N.A.S.
By hibbs in forum SubtitleReplies: 5Last Post: 26th Jul 2020, 21:07 -
Subtitle Edit: How to see original sub for translation but not its timings
By AmirATM in forum SubtitleReplies: 0Last Post: 20th Mar 2019, 03:58 -
Subtitle Edit Generating Blank srt with timestamps
By aoife in forum SubtitleReplies: 1Last Post: 6th Nov 2018, 11:37
