Hello everyone!
I searched the forum, I found similar issues, but I have yet to find a solution to this particular one.
In the past, I successfully exported audio from PAL 25 fps videos in my language and add it to NTSC 23.976 fps (after converting the 25 fps audio track to 23.976).
However, this time is different. I tried several tools and realized that the issue was not in the tool used to convert 25 fps audio to 23.976 fps, but rather in the video itself.
Basically, after conversion and checking in Avidemux that I needed to slightly anticipate the audio of -1200 ms, the audio and video were synchronized only in the first 20 minutes. The remaining 20 minutes circa (it's an episode) are out of sync: I suspect a black screen between 2 scenes is slightly longer in the 23.976 fps version, which"ruins" the sync between the 2.
Is there a tool that allows us to quickly fix this that is NOT time-consuming, if any? I am asking this because I am afraid I will have to add this extra step to all other episodes... and if it's too complicated or too long, I would honestly give up.
Just for the record, these are the steps I took so far:
1. Collected video 1 (low-quality PAL 25 fps with the audio track in my language) and video 2 (good quality NTSC 23.976 fps only in the English language)
2. Used MediaInfo to compare fps between the 2 videos.
3. Used TFM Audio Tool to extract and convert video 1's audio to 23.976 fps.
4. Imported converted video 1's audio and video 2 inside MKVToolNix to create a new single video.
5. Checked in Avidemux the aforementioned new video the time difference between audio and video.
6. Adjusted the audio timing in MKVToolNix as per Avidemux's result and saved the file again.
Thanks to anyone in advance.
Edit them to match. There is no easy way if there are different cuts
There is no tool that will figure out if a scene is deleted or added and fix them automatically -
@johns0 thank you.That thread was actually the first one I read, but it seems like the OP did not find any solution to the issue.
@poisondeathray thanks, this is what I suspected.
I am not actually looking for a tool that fixes them automatically, but is there any process that is quick enough to be repeated without making the whole process too long, since this is going to be applied to several episodes? Which tool or process would you use in my place (assuming the issue is only in a longer black screen between scenes)?
Properly reduce 30 & 29.97 fps to 23.976 fps
By kalemvar1 in forum Video ConversionReplies: 2Last Post: 10th Jul 2022, 11:02 -
Converted Audio Streams won't synch - FPS issue?
By daigo99 in forum Video ConversionReplies: 5Last Post: 23rd Nov 2020, 21:21 -
how can I mux 25 fps audio into 23.438 fps (1024 spf) ?
By precipizio in forum AudioReplies: 12Last Post: 16th Apr 2020, 14:06 -
Virtualdub 23.976 fps to 29.97 fps
By luciofulci in forum Video ConversionReplies: 14Last Post: 11th Mar 2020, 16:30 -
Ultimate Guide for Interlaced (29,97 fps) to Progressive (23,976/59,94 fps)
By kalemvar1 in forum Video ConversionReplies: 9Last Post: 22nd Dec 2018, 06:49
