Results 1 to 14 of 14
  1. ( I use google translate, I hope I can make myself understood )
    Hello!!!
    I am new to encrypted videos. Thanks to the explanations of Angela, [ss]vegeta and cedric8528, I was able to recover a video by following their advice, thanks to them. But I think I'm having trouble doing something, because my video is unreadable, the screen is green. I saw an error message while recovering the video under N_m3u8DL-RE.
    Could you help me, please
  2. green video because need key to decrypt ...
    so if you don't provide some data value, like lic url and pssh, need video link to get this data
  3. Thank you for answering me loméro.
    I've found :
    PSSH: AAAAjXBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAG0IARIQVi ZiNv1mNs+IKdW4Z4Ie/hoIY2FzdGxhYnMiRGV5SmhjM05sZEVsa0lqb2lNRGd5TW1ZeFl qY3RZbU13TXkwMFlUUTVMV0UzTkRjdE1HRTBZbU00TjJSbU1UY zRJbjA9MgdkZWZhdWx0
    URL lic: https://lic.drmtoday.com/license-proxy-widevine/cenc/
    Do you think I was wrong
  4. if you are able with python use this lic url
    https://lic.drmtoday.com/license-proxy-widevine/cenc/?specConform=true
    if not, share here auth value from lic url
  5. Ok, thanks,
    I don't know python,but I will try
  6. I tested and I put your code in python, but it put invalid syntax
  7. Solved, thanks to lomero help
    May 2023
    Singapore
    Hello!!!
    Hello, I'm facing the same issue here. Have what I think is the correct mpd, PSSH, KID, lic-url, but running l3.py to try and find the key gives me this:
    [Attachment 70701 - Click to enlarge]
  9. Originally Posted by Rilakkumazzz View Post
    Hello!!!
    A 400 Bad Request is often a sign that there's additional json data needed in the request, or maybe a missing token in the headers. Post site and request info here or in PM and someone will be able to help you better.
    May 2023
    Singapore
    OK, hmm. Thanks. This is the video I'm trying to grab:
    https://vtm.be/vtmgo/afspelen/8ebd7984-b24b-46e2-9443-c40b8753d0db
    This is what I have so far. I'm new to this so this may likely be erroneous 😬
    KID:
    6e4a6a24633a3a13bf9725508941782d
    PSSH:
    AAAAMnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABISEG5Kai RjOjoTv5clUIlBeC0=
  11. You've come pretty far for being new, though. Nice work. The only thing missing is that you need the x-dt-auth-token only as a header. Remove everything else and it should work. And make sure there's no spaces in that PSSH.
    May 2023
    Singapore
    Thanks for the tip! I edited my headers.py to include x-dt-auth-token, and this is what I keep getting after multiple runs:
    [Attachment 70709 - Click to enlarge]
    I notice there's a '…' or ellipsis in the x-dt-auth-token, and neither WKS-KEYS nor cdrm-project seems able to proceed after this. Have tried rebooting my player and computer several times to try and generate a new token, but it does not seem to work and now I might be back at square one. :/
  13. I'm not entirely sure what's going there.
    Grab the token from the headers tab of the license, like this:
    [Attachment 70711 - Click to enlarge]
    Add that token as your only header to headers.py, like this:
    headers = {
        'x-dt-auth-token': 'tokengoeshere',
    Then use WKS like you've been doing:
    PSSH: AAAAjXBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAG0IARIQvuWgjvT/Pd6ZYuGBFym8hRoIY2FzdGxhYnMiRGV5SmhjM05sZEVsa0lqb2laREpqTkRkbU9EZ3RabVUyWWkwME5UVmlMV0psTnpRdFpEQXhPVEkyTjJWa01UWmxJbjA9MgdkZWZhdWx0
    License URL: https://lic.drmtoday.com/license-proxy-widevine/cenc/?specConform=true
    --key 6e4a6a24633a3a13bf9725508941782d:f4568f6e22de6cff5be421a52cfeeb1a
    --key e0df46a5af003319a6196b7523523e0b:86c559d741b65c2c91d77aea6b3155d0
    --key bee5a08ef4ff3dde9962e1811729bc85:1c8760930a324ab1bffcb16dfc4fcc63
    --key 303144223e863bc5b4fbdc537e9d2613:d16d0e782e20caee73c28a5bce813c1f
    --key 59753f1fc3a63765aad05d018e30cd1f:274a46851c577926802ddba9d64ce891
    --key fa3095d6dc6f4585b0b25829e481643d:c86583753e120ec016f671b7f8bb8ba1
    --key 4517ece39c0a3f7cb95707661e5e5b22:69c1d8ecc5e03f004e297603b096d1a8
    May 2023
    Singapore
    Thank you so much for your help again, and sorry for the trouble. I'm not sure why it did not work, probably had to do with how the auth token was authenticated. Oh well, more practice it is!
