Sorry if these are stupid questions, I'm quite new to this.
Looking to start digitising my own Digital 8 tapes rather than having someone else do it. Is there a recommended capture card/software thats widely used by people on here? Also digital 8 seems to be a newer format so is there a way to digitise it without a capture card?
Would appreciate links to any videos or resources detailing the digitisation process that you'd recommend.
Thanks!![]()
I am on Mac so would not be able to use WinDV unfortunately. Is it possible to use this cable:
https://www.amazon.co.uk/Firewire-Adapter-Compatible-DCR-TRV75E-Accessories/dp/B0BWN3B...s%2C259&sr=8-4
alongside a capture software?
Also what about Firewire>Thunderbolt>USB-C cables and a capture software?
Essentially I'm asking is it possible to do without a firewire card as i'm not sure how I would use one of those with a Macbook?
Thank you! -
It would have helped had you stated you are a Mac user since you posted in a PC forum. Compounded by you not stating the model of Mac you have or the camcorder.
Mac 'DV' transfer has been discussed many times but the simplest is to look on Youtube as there are many videos which show what cable(s) you need and the software you need. Such as
https://www.youtube.com/watch?v=fs4uJeutYp8
Digital8 LP vs SP...21 years later
By ybarra in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Jul 2022, 02:39 -
How can you tell Digital8 vs. HI-8?
By seanmcnally in forum Capturing and VCRReplies: 90Last Post: 12th Apr 2022, 19:17 -
Digital8 Errors - is it the camera, or the tape?
By seanmcnally in forum Capturing and VCRReplies: 1Last Post: 12th Mar 2022, 15:36 -
My Digital8 Camera not play video
By Ferggue in forum Video ConversionReplies: 12Last Post: 29th Jun 2021, 23:56 -
DV Artifacts/Scan Lines? (Digital8)
By BillyJeanB in forum Capturing and VCRReplies: 9Last Post: 5th Jan 2020, 16:35
