  1. [redacted]
  2. Not sure whether it helps, but last time I needed to do this I used py7zr (https://github.com/miurahr/py7zr#sevenzipfile-class-usage).
  3. using py7zr i found out that it is actually an xz file and not a 7z, that's why py7zr doesn't work.
  4. This site:
    https://www.motobit.com/util/base64-decoder-encoder.asp
    Your information from file.txt:
    0>_Td6WFoAAATm1rRGAgAhARYAAAB0L-Wj4ACGAIBdAGBjDARYU9IPq5mM5TC1tKx2D4Z9C95Tx-NebTZLYyKgDjTPvxcbwpPz8oZfVeIyRUgAU9d5XWJ27CWuIdla Fj7VZsPIoq1Fwr7guvLw2kulPgwy1lWzWa_9A5egK0LbwGYA22 UlJ9W2QLa1Aesd2j1gRhFl4AzPhu9ppn6C3dcAALxCQXwGxQqe AAGcAYcBAADgz93lscRn-wIAAAAABFla
    Converted at that website results - Base64 representation of the data:
    MD5fVGQ2V0ZvQUFBVG0xclJHQWdBaEFSWUFBQUIwTC1XajRBQ0 dBSUJkQUdCakRBUllVOUlQcTVt
    TTVUQzF0S3gyRDRaOUM5NVR4LU5lYlRaTFl5S2dEalRQdnhjYn dwUHo4b1pmVmVJeVJVZ0FVOWQ1
    WFdKMjdDV3VJZGxhRmo3VlpzUElvcTFGd3I3Z3V2THcya3VsUG d3eTFsV3pXYV85QTVlZ0swTGJ3
    R1lBMjJVbEo5VzJRTGExQWVzZDJqMWdSaEZsNEF6UGh1OXBwbj ZDM2RjQUFMeENRWHdHeFFxZUFB
    R2NBWWNCQUFEZ3o5M2xzY1JuLXdJQUFBQUFCRmxh
