I own a ton of movies and tv shows, and I always enjoyed tinkering with them, cutting out awesome battle scenes into their own separate videos and stuff, but now I've taken on a bigger task that I have always wanted to do, but unfortunately my tools are not up to the task. Right now I'm using Machete (a keyframe editor) and Smart Cutter (a frame-accurate cutter that uses smart rendering) as well as ffmpeg for the initial lossless transition from DVD to video, and my goal is to join some of my favourite TV shows together seamlessly, cutting out credits and commercial transitions, making the start and end of each episode splice seamlessly too. There will be one credit scene at the end of each video and an opening scene at the beginning, and each video will span an entire arc. What I'm having problems with is transitions, sometimes I might need the video and/or audio to fade out/in, but if I'm gonna preserve DVD quality then whatever tool I use for this must support smart rendering. As I understand it the idea behind smart rendering is that the only frames that are edited are the frames you are working on, the rest of the untouched video is simply muxed. I have seen this used in tools to cut video in a frame-accurate fashion, which gives you more options than a keyframe editor, but it stands to reason you could do more than just splice video with this technique. Are there any good tools out there that might help?
Results 1 to 14 of 14
Smart rendering works, as you describe it, for a single video although that may even fail when you add another sequence beit a credit or transition since the bitrate for these will inevitably be different so re-encoding must then take place.
Expand that to entire episodes where the bitrate for these will, inevitably, vary and the entire new video will require re-encoding. -
Well no, actually the series I'm working on is mostly the same, there is some variance but mostly from season to season so doing entire arcs works fine, I just combine the files with machete first, or I can concatenate the videos losslessly with ffmpeg. The files are all joined, at this point I just need to smooth over the transitions.
I did most of my work in Machete this time, though Smart Cutter does come in handy. Luckily, the videos have the original keyframes intact, so I can make cuts at the transitions between scenes. If I cut out two keyframes and edit them in smart cutter I can make them fit together better and insert the video back in with Machete, but I can't add effects with this technique, only thing. If I have to carve out each transition again and edit them individually I will, but it would be faster to edit the whole video with a program that supports smart rendering
Maybe it's the same bitrate because it's animated?Last edited by imkira3; 28th Apr 2023 at 17:15.
I'm reading the download page but it sounds like another tool like my smart cutter, but it does sound like it has a few useful tools in terms of video repair. Still, it's not listing anything about fading the video and/or audio out/in, which is what I need really
The audio can handled separately in an audio editor then remuxed with the video once it's ready.
Have you looked at Tmpgenc Smart Renderer, probably one of the most full-featured of its type
https://tmpgenc.pegasys-inc.com/en/product/tmsr6.html -
Unfortunately, VideoReDo TVSuite V6, which could add fades, is no longer available for sale due to the death of it's owner.
I also suggest that you look at Tmpgenc Smart Renderer.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Newly added Easing function to transition effects.
An easing function is newly available for the transition effects. By adding acceleration, deceleration or rebound to the animation movements, you can add further enhanced movement to the video footage.
Transition Effects.
Implements over 200 "Transition Effects" to choose from, ensuring that you can add your own unique touch to your videos. This version features new effects such as Page Turn, Grid and more
Wow! This sounds promising! I'm gonna give the free trial a try right now, it sounds perfect, exactly what I'm looking for -
H265 Smart Rendering Software
By Fox_25 in forum EditingReplies: 6Last Post: 1st Feb 2023, 21:27 -
Lossless Editing/Smart Rendering VC-1
By koberulz in forum Newbie / General discussionsReplies: 0Last Post: 29th Nov 2020, 21:57 -
What are some good editors that utilize smart rendering?
By imkira3 in forum Video ConversionReplies: 6Last Post: 18th Jul 2019, 09:22 -
suggestion on video program with smart rendering and transitions
By perfection in forum Newbie / General discussionsReplies: 2Last Post: 31st Jul 2018, 08:34 -
Is smart rendering on MP4 files possible?
By twinaleblood in forum EditingReplies: 4Last Post: 24th Jun 2018, 16:51
