Hello everyone,
I tried to download a livestream by using streamlink as my downloader, but It does not work as it gives me the following error:
I already got the key for this livestream so decrypting is no problem.error: https://p-nowlive.secure.footprint.net/live/rtl1hd/dash/rtl1hd.mpd is protected by DRM
May someone can help me for downloading encrypted?
Results 1 to 16 of 16
try with N_m3u8DL-RE
Example for a recording of 2 Minutes.
Code:./N_m3u8DL-RE --key-text-file key.txt --save-name mylive "https://p-nowlive.secure.footprint.net/live/rtl1hd/dash/rtl1hd.mpd" --mp4-real-time-decryption --live-real-time-merge --live-record-limit 00:02:00 --mux-after-done mp4
you are not looking for anything on your own...-(
this forum is a bible....you just have to use the search tab...
Code:./XstreamDL_CLI.cli --select --live --live-duration 00:02:00 --key ....... "yourfile.mpd"
your first Lesson...
https://www.wikihow.com/Run-a-Program-on-Command-Prompt
After That, you will be able to run ./N_m3u8DL-RE -
Hello, I tried but I got this error:
N_m3u8DL-CLI_v3.0.2.exe --key-text-file keys.txt --save-name mylive "https://p-nowlive.secure.footprint.net/live/rtl1hd/dash/rtl1hd.mpd" --mp4-real-time-decryption --live-real-time-merge --live-record-limit 00:02:00 --mux-after-done mp4
N_m3u8DL-CLI 3.0.2.0
USAGE:
N_m3u8DL-CLI <URL|JSON|FILE> [OPTIONS]
OPTIONS:
ERROR(S):
Option 'key-text-file' is unknown.
Option 'save-name' is unknown.
Option 'mp4-real-time-decryption' is unknown.
Option 'live-real-time-merge' is unknown.
Option 'live-record-limit' is unknown.
Option 'mux-after-done' is unknown.
--workDir Set work dir (Video will be here)
--saveName Set save name(Exclude extention)
--baseUrl Set Baseurl
--headers Set HTTP headers,format: key:value use | split all
key&value
--maxThreads (Default: 32) Set max thread
--minThreads (Default: 16) Set min thread
--retryCount (Default: 15) Set retry times
--timeOut (Default: 10) Set timeout for http request(second)
--muxSetJson Set a json file for mux
--useKeyFile Use 16 bytes file as KEY for AES-128 decryption
--useKeyBase64 Use Base64 String as KEY for AES-128 decryption
--useKeyIV Use HEX String as IV for AES-128 decryption
--downloadRange Set range for a video
--liveRecDur When the live recording reaches this length, the
software will exit automatically(HH:MM:SS)
--stopSpeed Speed below this, retry(KB/s)
--maxSpeed Set max download speed(KB/s)
--proxyAddress Set HTTP/SOCKS5 Proxy, like http://127.0.0.1:8080
--enableDelAfterDone Enable delete clips after download completed
--enableMuxFastStart Enable fast start for mp4
--enableBinaryMerge Enable use binary merge instead of ffmpeg
--enableParseOnly Enable parse only mode
--enableAudioOnly Enable only audio track when mux use ffmpeg
--disableDateInfo Disable write date info when mux use ffmpeg
--disableIntegrityCheck Disable integrity check
--noMerge Disable auto merge
--noProxy Disable use system proxy
--registerUrlProtocol Register m3u8dl URL protocol
--unregisterUrlProtocol Unregister m3u8dl URL protocol
--enableChaCha20 enableChaCha20
--chaCha20KeyBase64 ChaCha20KeyBase64
--chaCha20NonceBase64 ChaCha20NonceBase64
--help Display this help screen.
--version Display version information. -
N_m3u8DL-RE.exe not N_m3u8DL-CLI_v3.0.2.exe
https://github.com/nilaoda/N_m3u8DL-RE/releases/tag/v0.1.6-beta -
Hello everyone,
I already downloaded a DRM video and decrypt it successfully but has not synced the audio & video can anyone know how to resolve it.
Here are video links and other info:
mpd:
https://cdn.blutv.com/5bd2f293ac08fb00066d2b88/outputs/5da0843fe6fcf000078e49b2/v3/dash-0/output.mpd
PSSH:
AAAANHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABQiDF2ghD/m/PAAB45Jskjj3JWbBg==
License:
https://wdvn.blutv.com/
Keys:
mp4decrypt.exe --key edc331ee18035a2ab7908ece8ec39669:a9d834b4571f2be3d bdb61fb4fb5a157 --key c0302429ddcf5349a5a042b64e1aac16:613cedd44fe1a2073 31600ba12fdf487 --key 3933afcde1775dc8902644bb286fcec7:f85f1502f3123da23 70811285ca24a0d --key bfdadd353a085a19b48b893fc7ca933e:1e22c655bd49d901f 22ac432bdac30e8 --key c82dfd3d0f5e5b2a91354af9b088bb9f:a95e4130dc24d89bb 42e12f0622ecab4 v.mp4 v_dec.mp4
mp4decrypt.exe --key edc331ee18035a2ab7908ece8ec39669:a9d834b4571f2be3d bdb61fb4fb5a157 --key c0302429ddcf5349a5a042b64e1aac16:613cedd44fe1a2073 31600ba12fdf487 --key 3933afcde1775dc8902644bb286fcec7:f85f1502f3123da23 70811285ca24a0d --key bfdadd353a085a19b48b893fc7ca933e:1e22c655bd49d901f 22ac432bdac30e8 --key c82dfd3d0f5e5b2a91354af9b088bb9f:a95e4130dc24d89bb 42e12f0622ecab4 a.m4a a_dec.mp4
ffmpeg.exe -i v_dec.mp4 -i a_dec.mp4 -c copy final.mp4
Thanks in advance!Last edited by Hafiz; 4th Sep 2023 at 07:59.
Yeah, I see I've forgotten keys, here they are:
mp4decrypt.exe --key edc331ee18035a2ab7908ece8ec39669:a9d834b4571f2be3d bdb61fb4fb5a157 --key c0302429ddcf5349a5a042b64e1aac16:613cedd44fe1a2073 31600ba12fdf487 --key 3933afcde1775dc8902644bb286fcec7:f85f1502f3123da23 70811285ca24a0d --key bfdadd353a085a19b48b893fc7ca933e:1e22c655bd49d901f 22ac432bdac30e8 --key c82dfd3d0f5e5b2a91354af9b088bb9f:a95e4130dc24d89bb 42e12f0622ecab4 a.m4a a_dec.mp4 -
How to download mpd stream (DRM protected)?
By ddim in forum Video Streaming DownloadingReplies: 320Last Post: 23rd Jun 2024, 19:01 -
MPD DRM protected live stream
By snow_ in forum Video Streaming DownloadingReplies: 14Last Post: 7th Sep 2022, 17:11 -
mpd protected with DRM?
By chisdchisdq in forum Video Streaming DownloadingReplies: 21Last Post: 24th Mar 2022, 23:14 -
By bodasaud in forum Video Streaming DownloadingReplies: 5Last Post: 3rd Feb 2021, 08:41 -
Downloading mpd stream (DRM protected?)
By odyssey1234 in forum Video Streaming DownloadingReplies: 8Last Post: 14th Aug 2019, 22:26
