I tried already Vapoursynth: "MC Temporal Denois", "DeHalo_alpha", "HQDering", "stabilizeIT" and "ReduceFlicker" (all default Setting and i used only one at the same time).
Nothing really helped. Im bad in finding out how an "artefact" is called, so i have also problem by finding out which filter i have to use.
Here the Video (i have two examples):
1: It's upscaled. Look on the hand on his head on the metalplate this upper dot. It wobbles around: https://uploadnow.io/de/share?utm_source=D6RJtFJ
2. At the bottom below the girl it flickers at start of the video. After camera goes down the whole upper part flickers (original and upscaled): https://uploadnow.io/f/mT20HVF
What would you call this flicker? And which filter do you use on these kind of artefacts?
Do you normally "deflicker" before or after upscaling? In the first example i did not even saw the flicker. I saw it only on the upscaled one and now, when i look closer i see it on the original too. So i mean, sometimes its hard to regonize that in very blurry original files. Maybe it's also easier to remove after upscaling ?
Has anyone an idea ?
Edit: when i use "reduce flicker" in Vapoursynth-frame-stabilize, its horrible, when camera starts moving.
Flickering: I do not see it
Maybe SMDeGrain with dct=1 (this will slow down things) helps,...
Normally you, try to remove problems before scaling (especially scaling up) since scaling changes the nature of things (artifacts and noise get larger and worse).
StabilizeIT does zoom into a clip to hide shaking borders, it's meant to compensate a shaking image.
ReduceFlicker performs averaging of a frame with its two adjacent temporal neighbors, it's meant for luma flickering.users currently on my ignore list: deadrats, Stears555, marcorocchini -
What do you mean it will slow down? Processing-time or you mean movement in the video ?
I tried SMDeGrain with default-setting and it helps a little bit. but i don't find "dct=1". I see "dct" but there is only text and no numbers in dropdown-menu. You mean "use block DCT..." ?
And ok, ReduceFlicker does anyway does not work for me. -
I see "dct" but there is only text and no numbers in dropdown-menu.users currently on my ignore list: deadrats, Stears555, marcorocchini -
I see only a preview for the video in the lower right corner in filter tabusers currently on my ignore list: deadrats, Stears555, marcorocchini
RealCUGAN in hybrid vs Waifu 2x Extension Gui (slow in hybrid)
By Platos in forum Newbie / General discussionsReplies: 1Last Post: 28th Apr 2023, 05:43 -
Unable to get Hybrid to work
By Leanoric in forum Newbie / General discussionsReplies: 8Last Post: 11th Mar 2023, 13:17 -
New to HYBRID - set in/out?
By Jan Tokki in forum Newbie / General discussionsReplies: 5Last Post: 26th Jul 2022, 03:53 -
Hybrid error
By radusound in forum Newbie / General discussionsReplies: 40Last Post: 21st Mar 2021, 10:02 -
Hybrid Video Interpolation
By bradwiggo in forum Newbie / General discussionsReplies: 7Last Post: 6th Mar 2021, 09:14
