Results 1 to 10 of 10
  1. I own IDM which downloads newest episodes without issue. But it's unable to find the videos for the earliest ones, such as episode 1 below. I'd like to figure out how to get episodes 1-5 if possible. Thank you!
    https://www.rtve.es/play/videos/masterchef/programa-1/6841095/
  2. It looks like episode 1-5 are actually mpd files and DRM protected, while episode 6 and onward are m3u8 and not protected. IDM can't handle encryption, so that's why it can only download the newer ones. You need to use another downloader that can download encrypted videos, like N_m3u8DL-RE, and decrypt them using specific keys. It's a step above using something like IDM, but that's how it goes.
    I gathered the links and keys for you:
    Episode 1:
    URL: https://rtvedrmstaging.rtve.es/95/10/6841095/6841095_drm.mpd?idasset=6841095
    --key 401545667c6f114e8cb6759d29204011:9447f717aa9d110665e37b0746649a49
    Episode 2:
    URL: https://rtvedrmstaging.rtve.es/20/34/6843420/6843420_drm.mpd?idasset=6843420
    --key f8db5d1743fe8762bdc4b3803a310b77:b673cb0118f1006b16cd11f31c7c95a8
    Episode 3:
    URL: https://rtvedrmstaging.rtve.es/57/58/6845857/6845857_drm.mpd?idasset=6845857
    --key 507bffa6473d46cfbe13abfa2f13df17:b7c8d79bef7d22bf22f520afbdcc7c0f
    Episode 4:
    URL: https://rtvedrmstaging.rtve.es/04/60/6846004/6846004_drm.mpd?idasset=6846004
    --key 9150f0584a15e718bfec7b607bcb05ca:e6c48eae3ebe787188b9934e5d958602
    Episode 5:
    URL: https://rtvedrmstaging.rtve.es/81/18/6851881/6851881_drm.mpd?idasset=6851881
    --key 1d8146a005774555b9f9f3d8f853ece5:e05165ec519371465c00e3f21798df04
  3. Originally Posted by stabbedbybrick View Post
    Episode 1:
    Episode 2:
    Episode 3:
    Episode 4:
    Episode 5:
    Thank you. I really appreciate the help.
    Everything looked promising with the downloading and merging but when N_m3u8DL-RE finished, the end result was a blank video and no audio. (Mediainfo only shows a video stream.) I'm going to try again and see if I might have done something wrong, which is the likely scenario.
  4. Works fine on my end. Make sure you have ffmpeg and mp4decrypt installed, in order to properly support merging and decrypting.
  5. also, send through the command you were using with N_m3u8DL-RE that failed and the output and we can probably work out the problem
  6. OK, so I was missing the mp4decrypt portion. I thought I had entered the proper commands in N_m3u8DL-RE but I ended up with separate files for audio, video and subtitle. It was just a matter of merging them with ffmpeg and all was well.
    Thank you for your expertise and willingness to share! It seems that is more of a rare commodity these days.
    Incidentally, I found a site that handles the decryption for this site and several others, so I'm hoping it won't disappear so I don't bother you guys.
    Thanks again!
    Jan 2025
    Madrid
    Episode 1:
    Episode 2:
    Episode 3:
    Episode 4:
    Episode 5:
    I have reached the links to the .mpd files
    Can you please guide me on how to get the keys?
  8. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Jan 2025
    Madrid
    Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    Thank you very much. The tool was working for a while then stopped and can't pick up keys anymore. Do you know of a solution? I tried deleting and reinstalling it. I tried going back to an older version of Chrome. I tried everything.
  10. Member G.T.X.R's Avatar
    Jan 2025
    Europe
    I use this method on rtve: logout from rtve account >> clear cookies >> restart modem/ router if you have dynamic ip >> start vpn >> login to rtve >> then widevineproxy2 works fine, also yt-dlp with --allow-u or n_m3u8dl-re. Tested on Windows 10 and Firefox 139. Also this site works: https://www.descargavideos.tv/
