I have some older movies (probably taken with cheaper devices)
where say every second frame is a duplicate.
(For expample technical it's 30 fps, but actually it's only 15 fps.)
When removing the duplicates and saving the movie,
it seems to play more "stuttering" than the orig version.
My question:
Does the decoder do some kind of "smoothing improvement" when playing
movies with duplicates?
If so, it would be better to leave the duplicates in the movie?
If what you say is true, then in terms of cadence there is no difference in the smoothness of motion.
But your analysis might be wrong, or perhaps it was improperly decimated, removing some unique frames
If you re-encode with a lossy codec, then there is quality loss - but not in terms of a cadence change assuming you used adequate bitrate.
Or maybe the saved format predisposes to playback issues. eg. AV1 or VVC are difficult to playback on older hardware and could stutter or drop frames during playback
NoMy question:
What was your reason for removing them ?If so, it would be better to leave the duplicates in the movie? -
I did no formal analysis but just frame-wise looked at the movie (here and there).
The pattern was not exactly as AABBAABBAABB...
but with some disturbances like AABAAABBAABB...
I removed every second frame with VD2's frame rate menu.
(The disturbances shouldn't be any problem then).
When playing the saved result, it seemed (?) more stuttering.
I removed the duplicate to let reflect the fps the reality:
It is 15fps, not 30 fps.
Also for Deshaker filter to work correct.Last edited by nji9nji9; 25th Apr 2023 at 16:32.
There is no visual difference between 15 FPS unique frames, and 15 FPS unique frames duplicated to 30 FPS .
Because the pattern isn't exact, a more likely explanation is some unique frames were dropped. Verify the results of the decimation - Check frame by frame.
That's a valid reason - remove duplicates before application of any temporal filteringI removed the duplicate to let reflect the fps the reality:
Converting 60fps to 25fps and removing duplicate frames
By rgr in forum Video ConversionReplies: 2Last Post: 30th Sep 2022, 07:34 -
Removing duplicate lines
By [ss]vegeta in forum SubtitleReplies: 1Last Post: 17th Mar 2021, 02:52 -
Removing all duplicate frames in a video clip
By ecortez in forum EditingReplies: 0Last Post: 10th Mar 2021, 21:23 -
Removing duplicate frames from YouTube 60fps to 23.976 fps
By AndersonJames in forum RestorationReplies: 39Last Post: 5th Aug 2020, 23:47 -
Visual Sub Sync - Can't see the video - Black Frame
By elipiro92 in forum SubtitleReplies: 1Last Post: 13th Sep 2019, 13:55
