  1. Hy, i try to use RealCUGAN Tile Size in Vapoursynth-Frame-Resize-Resizer-RealCUGAN.
    If i want to change Tile Size its not possible. Its grayed out. Even if i check "force tile Size". Why i cant set a different number ?
    And what does Sync-Gap actually mean ? Has someone an idea ? Doesnt get what it does really.
  2. Originally Posted by Platos View Post
    I don't use hybrid, but it's the NCNN version
    https://github.com/Kiyamou/VapourSynth-RealCUGAN-ncnn-Vulkan
    syncgap
    Optional parameter. Default: 2.
    Sync Gap. Reduce the impact of image blocking. It's a trade-off between speed and quality.
    Value range: 0, 1, 2, 3.
    syncgap = 0: without process for sync gap (fast).
    syncgap = 1: lossless (slow).
    syncgap = 2: some loss for background, less loss for texture (middle).
    syncgap = 3: more loss for background, less loss for texture (fast).
    Not sure about hybrid's tilesize, but it has to be mod32 for that version
  3. it's a bug, force tile size simply doesn't enable the ui elements, since I forgot to connect those controls
    I might find time to fix it over the weekend,..
  4. Originally Posted by Selur View Post
    Ahh, no problem. Yeah if you find time, would be cool. But no Hurry. Im glad this software is available. Otherwise i think i would never went into Avisinth and now Vapoursynth-stuff.
    Im trying out filters now
