Guys
I tried to download an episode of my favorite series, 2 days ago you could use mpd to download the video and decrypt it
but now it seems that the encryption system has changed
when i try to download the file with streamlink this is the output
Code:[cli][info] Available streams: 288p_alt2 (worst), 288p_alt, 288p, 432p_alt2, 432p_alt, 432p, 720p_alt2, 720p_alt, 720p, 1080p_alt2, 1080p_alt, 1080p (best) [cli][info] Opening stream: 1080p (hls-multi) [utils.named_pipe][info] Creating pipe streamlinkpipe-7816-1-4784 [utils.named_pipe][info] Creating pipe streamlinkpipe-7816-2-8748 [stream.hls][error] Failed to create decryptor: ('Unable to decrypt cipher {0}', 'SAMPLE-AES-CTR') [stream.hls][error] Failed to create decryptor: ('Unable to decrypt cipher {0}', 'SAMPLE-AES-CTR') [cli][error] Try 1/1: Could not open stream <Stream()> (No data returned from stream) error: Could not open stream <Stream()>, tried 1 times, exiting [cli][info] Closing currently open stream...
https://watch.sling.com/1/asset/632503316f294cd081e01ae6e6c25dfe/watch
I also downloaded what I could with the live cat chrome extension, but it results in a file that I can't decrypt
https://mega.nz/file/WZhQ2TKZ#PlVlxxfjcL-hfZ25S3TdVPhtDZGhzz3DBaPF6TqtGik
--key 0d57c289b3e541f0ae437d44ecd75431:40e58b5844c83c76c 870237f2c2ea536
pls:help
Are you sure you are downloading from the correct link ?
Not sure if this will work for you , but try it anyway:
Open dev tools and navigate to network tab , in the filter type "Auth" look for the one with response then look for "dash_manifest_url" and try to download from that link:
[Attachment 70509 - Click to enlarge]
PS: if you got mpd link with "spanning_ads.mpd" at the end it maybe not be valid , so try to refresh the page and try again .
I hope someone provides you with a better/easier method for this service.
RegardsLast edited by thej911; 25th Apr 2023 at 00:40.
finally worked
thank you very much bro
https://imgur.com/a/naJi11G
mpd problem
By vodott in forum Video Streaming DownloadingReplies: 1Last Post: 17th Apr 2023, 15:52 -
limited MPD?
By Jawz22 in forum Video Streaming DownloadingReplies: 8Last Post: 19th Oct 2022, 14:48 -
mpd ini
By seremedy in forum Video Streaming DownloadingReplies: 1Last Post: 18th Apr 2021, 03:19 -
Help with MPD
By dzigelbaum in forum Video Streaming DownloadingReplies: 8Last Post: 18th Mar 2021, 05:05 -
Download this mpd... help
By leoglez29 in forum Video Streaming DownloadingReplies: 4Last Post: 17th Jul 2020, 23:25
