I have two video files:
- Movie A (low quality 25fps video, English audio) CLICK FOR MEDIAINF0 FILE
- Movie B (good quality 23,976fps video, Hungarian dub) CLICK FOR MEDIAINF0 FILE
I want to remux them to create movie C (audio from A, video from B). I tried a few methods and the output is always out of sync.
- TFMAudioTool (enable framerate conversion - PAL to NTSC, output format: MP3 CBR 320kbps)
- Clever FFmpeg GUI (25 -> 23,976 fps, length + pitch, 48000Hz, AAC)
Then I use Reaper to import both the output AND Movie B so I can line up both audio tracks. I do this to avoid manually adjusting a/v sync while watching the movie. They both line up perfectly (both start and end). Then I render the readjusted track as 320kbps MP3 again (sigh).
Finally I use Avidemux to replace the track from Movie B with the track rendered with Reaper.
What else can I do?
Most likely the videos have different scene changes/length and that will cause sync issues,what you need to do is check the first part of the videos to see if they match and and if the scenes are different when going to the next part,if there's new additions to the video then it's not worth doing,if its the same video after the scene and the lengths are different then you need to edit all the scene changes so they match.
This is a fair point. I got so fixated on the technical aspect of this endeavour that I forgot how often movies get censored (cut 1 second here, cut 4 seconds there). You're right, it probably isn't worth my time.
I have another question, though. What exactly is SPF? I took a look at a few random movies I have and the FPS/SPF value in Mediainfo varies a lot:
Code:23,976 31.250 FPS (1536 SPF) AC3 23,976 38.281 FPS (1152 SPF) MP3 23,976 43.066 FPS (1024 SPF) AAC 25 46.875 FPS (1024 SPF) AAC 25 31.250 FPS (1536 SPF) AC3
Nothing to do with sync,just different codecs with different bitrates.
I took a closer look at one of the problematic movies and the framerate had a lot of anomalies. Some frames would get up to 5 duplicates. It all makes sense now.
Edit Video Track Separately From Audio Track in VideoPad
By meandersleut in forum EditingReplies: 0Last Post: 12th Sep 2022, 12:11 -
transplanting a single page menu - is it possible?
By Spiny Norman in forum Authoring (DVD)Replies: 2Last Post: 8th Jul 2022, 20:42 -
How to rip only audio track (no encode) from BD movie?
By vlp_007 in forum Blu-ray RippingReplies: 5Last Post: 26th Feb 2022, 11:02 -
How do I correctly decimate or turn a PAL DVD source from 25fps to 23.976?
By hihflappy in forum Newbie / General discussionsReplies: 10Last Post: 1st Dec 2021, 11:27 -
Movie File Size Reduction with Only Audio Track Name Change
By ngs428 in forum Newbie / General discussionsReplies: 7Last Post: 4th Jul 2021, 20:51
