  1. Hello,
    I'd like to make a DVD-A of some hi bit rate (24) .wav files. I have tried to use DVD-Author Gui which fails with a cryptic message that I cannot seem resolve:
    "DVD authoring failed" I'm using Win10 and I know this program is pretty old and unsupported.
    If someone knows the file structure I need I could attempt to create an ISO and burn it. Or, better still recommend a program that might support DVD-A creation.
    Thanks!
    P
  2. Member Cornucopia's Avatar
    Minnetonka's discWelder family of apps are AFAIK the only good, reliable way to author DVD-Audio discs, other than the $$$ pro Scenarist method using the DVD-Audio upgrade (if either are even available anymore).
    <edit> better and easier just to make an audio-centric Bluray, also known as pure-audio bluedisc, IIRC.
    <edit2> I forgot about this. Don't know how well it works/compatibility-wise, but this might suit you, since it is open source.
    https://dvd-audio.sourceforge.io/spec/hexcomps.shtml
  3. Thanks for your post, Scott! I wasn't aware of Discwelder so I will check it out.
    In the meantime, as I do own DVD Architect Pro which allows for PCM at 24 bits/96khz audio, made a simple DVD with only a basic menu and it plays and sounds great in all my DVD players, not just the compliant DVD-A players. Maybe this is all I need to do for my purpose.
    Cheers,
    Peter
