Hello,
I need a curl command to extract m3u8 URL from below website:
https://www.atv.com.tr/canli-yayin
The resulting URL will be something like this:
https://trkvz.daioncdn.net/atv/atv_720p.m3u8?e=1682287651&st=r6LEl3pdxdnOTroaZv7YwA&si...c185a314e&ce=3
Please note that the parameters "e", "st" and "sid" will change on each page reload.
Thanks in advance.
you take a python script too?
not a beautiful script, but working/ (do it in few seconds so for the fast i think its enough) script.
so i can test it only with 480p because my browser dont show me more.
you need to install python3
selenium
pip3
pip3 installs for the import
and google chrome stable version
Code:#!/usr/bin/env python3 # -*- coding: utf-8 -*- import os import requests from selenium import webdriver from selenium.webdriver.common.keys import Keys from selenium.webdriver.chrome.options import Options from selenium.webdriver.chrome.options import Options from selenium.webdriver.support.ui import Select import time import undetected_chromedriver as uc from selenium.webdriver.common.desired_capabilities import DesiredCapabilities from selenium.webdriver.support.ui import WebDriverWait from selenium.webdriver.support import expected_conditions as EC from selenium.webdriver.common.by import By import json import re options = uc.ChromeOptions() options.add_argument("--enable-logging=performance") options.add_argument("--enable-javascript") options.add_argument('--headless=new') options.add_argument("--no-sandbox") desired_capabilities = DesiredCapabilities.CHROME.copy() logging_prefs = {'performance': 'ALL'} desired_capabilities['goog:loggingPrefs'] = logging_prefs browser = uc.Chrome(options=options, desired_capabilities=desired_capabilities) browser.get("https://www.atv.com.tr/canli-yayin") time.sleep(10) m3u8_url_pattern = re.compile(r'https://trkvz.daioncdn.net/atv/atv_480p.m3u8*') logs = browser.get_log('performance') m3u8_url = None for log in logs: try: message = json.loads(log['message']) if 'message' in message and m3u8_url_pattern.match(message['message']['params']['request']['url']): # URL aus Eintrag extrahieren und in Variable speichern url = message['message']['params']['request']['url'] if m3u8_url is None and url.startswith('https://trkvz.daioncdn.net'): m3u8_url = url print(m3u8_url) except: pass
[Attachment 70495 - Click to enlarge] -
import requests import re headers = { 'Origin': 'https://www.atv.com.tr', 'Referer': 'https://www.atv.com.tr/', 'User-Agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/112.0.0.0 Safari/537.36', } resp1 = requests.get('https://securevideotoken.tmgrup.com.tr/webtv/secure?000000&url=https%3A%2F%2Ftrkvz.daioncdn.net%2Fatv%2Fatv.m3u8%3Fce%3D3%26app%3Dd1ce2d40-5256-4550-b02e-e73c185a314e', headers=headers).json() m3u8_url = resp1['Url'] print(f'\n{m3u8_url}\n') import requests headers = { 'accept': 'text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9', 'user-agent': 'Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/102.0.0.0 Safari/537.36', } resp2 = requests.get(m3u8_url, headers=headers).text atv_list = re.findall(r'#EXT-X-STREAM-INF:.*\n(.*\.m3u8.*)', resp2) for m3u8_res in atv_list: print(f'https://trkvz.daioncdn.net/atv/{m3u8_res}')
[Attachment 70515 - Click to enlarge]
curl, but python is better for this purpose..
Code:curl "https://securevideotoken.tmgrup.com.tr/webtv/secure?000000&url=https%3A%2F%2Ftrkvz.daioncdn.net%2Fatv%2Fatv.m3u8%3Fce%3D3%26app%3Dd1ce2d40-5256-4550-b02e-e73c185a314e" -H "Origin: https://www.atv.com.tr" -H "Referer: https://www.atv.com.tr/" -H "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/112.0.0.0 Safari/537.36"
Thank you guys both. Fantastic job.
@sk8ordi3
From where did you get the below URL. I don't see it in the network tab.
https://securevideotoken.tmgrup.com.tr/webtv/secure?000000&url=https%3A%2F%2Ftrkvz.dai...e-e73c185a314e -
you can "find it" here in dev menu
just figured out the numbers is "fake" so the zero's working..
[Attachment 70522 - Click to enlarge] -
who would be interested this is for vod contents:
Code:import requests import re print('\ntest link: https://www.atv.com.tr/kurulus-osman/121-bolum/izle\ntest link: https://www.atv.com.tr/akinci-cizgi-dizi/9-bolum/izle\n') link = input('link: ') headers = { 'authority': 'www.atv.com.tr', 'accept': 'text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9', 'user-agent': 'Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/102.0.0.0 Safari/537.36', } resp1 = requests.get(link, headers=headers).text video_id = re.findall(r'contentUrl\":\"(.*)_', resp1)[0].strip() headers = { 'Origin': 'https://www.atv.com.tr', 'Referer': 'https://www.atv.com.tr/', 'User-Agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/112.0.0.0 Safari/537.36', } resp2 = requests.get('https://securevideotoken.tmgrup.com.tr/webtv/secure?000000&url='+video_id+'.hb.smil%2Fplaylist.m3u8', headers=headers).json() m3u8_url = resp2['Url'] print(f'\n{m3u8_url}\n')
Way to get the m3u8 link for the NBC live stream from command line? (USA)
By Prairie Dog in forum LinuxReplies: 7Last Post: 13th Nov 2022, 06:09 -
How to extract the m3u8 or iptv link from this website ?
By icebreaker101010 in forum Video Streaming DownloadingReplies: 4Last Post: 15th Apr 2022, 23:42 -
How to fix the download failure with yt-dlp command for some live M3U8 link
By zydjohn in forum Video Streaming DownloadingReplies: 12Last Post: 26th Nov 2021, 14:35 -
download live m3u8 stream from 247stream website
By grabyea in forum Video Streaming DownloadingReplies: 0Last Post: 12th Oct 2021, 15:37 -
Curl or Wget command to capture vtt subs?
By daigo99 in forum SubtitleReplies: 3Last Post: 5th Sep 2021, 20:16
