  1. devdev devdev's Avatar
    Sep 2003
    im experiencing issues capturing mini tapes via firewire to prem 6.5 on xp (video drops out at a certain point for rest of video)
    and i'm looking to test an alternative capture sw to see if that works
    any suggestions what sw still works on xp that is reliable and i could try as an alternative to see if it fixes the issue?
    thanks in advance
  2. devdev devdev's Avatar
    Sep 2003
    thanks alwyn. will they capture in 16:9 btw ? actually the drop out is just once and for rest of recording but sound continues but out of sync. it happens on multiple tapes for two separate batches recorded of different machines . i will check if happens at same time
  3. devdev devdev's Avatar
    Sep 2003
    great guides btw!
    May 2005
    PAL User
    Cheers Devdev, Scenalyzer has an setting to choose 4:3, 16:9 or Automatic; WinDV doesn't. I'm not sure. I've just had a try but my system isn't playing nicely with Firewire at the moment.
  5. devdev devdev's Avatar
    Sep 2003
    hiya i maybe wrong alwyn but scenlyzer only captures 16:9 when ntsc?
    May 2005
    PAL User
    Dunno! I'm not in NTSC land. But one of the Capture options is to set 4:3, 16:9 or Automatic. Most DV is 4:3, so I'd be surprised if you can only capture NTSC in 16:9.
  7. devdev devdev's Avatar
    Sep 2003
    gonna try now! thanks alwyn
