Hello, I have been capturing video from miscellaneous sources and using numerous capturing devices for over 20 years. For the past 10 years, I have been using a Pioneer Elite Receiver (VSX-01TXH) as a switch for all of my various inputs (cable, laserdisc, VHS, etc). The receiver upscales all of the different signals to 1080i and outputs to the HDMI monitor output. I output this signal to two PC's and a TV using a splitter that strips the HDCP. On the two PC's, I am using the AverMedia C027 capture cards using the HDMI input and CyberLink PowerDirector as the capturing software. This has been a winning combination for all this time. That is, until recently. I have not needed to capture anything since last summer when I made some DVD's for a friend of some old VHS tapes. Everything seemed to be fine. The only hardware change that I made since then was to replace my Tivo Edge with a Fire TV Cube (which I did back in December 2022). Last week, I tried to capture some more VHS tapes, but all I can get is "HDCP" displayed on both of my capturing devices (the TV still seems to be working fine). I have tried replacing my splitter (HDCP stripper) but that didn't make a difference. I really don't understand what has happened. I welcome any insight as I am now completely out of ideas. Thank you all for your time.
Results 1 to 18 of 18
HDCP keys can be revoked.
https://en.wikipedia.org/wiki/High-bandwidth_Digital_Content_Protection -
Are you thinking the HDCP keys for this card have been revoked? If so, I don't suppose there is anything that can be done?
It's probably the splitter's key that has been revoked. It's believed that those splitters use keys stolen from some other legit device. The keys are probably old enough now that there are few of those original devices left in use. Intel probably thinks the few remaining owners will just think their old TV (or whatever) has died.
That does make sense; all of my other splitters could have the same stolen key too.
But how would Intel reach the splitter in order to revoke the key? All of the devices that connect to it (except my FireTV Cube, which I haven't captured from) have composite or S-video connections that connect to the receiver. My connection goes from the VCR to the receiver, to the splitter, to the capture card. The receiver isn't connected to the internet either.
Regardless, do you have any suggestions on what I should do? I appreciate your time. -
Any device in the chain with internet access or disc access can receive the revocation list and refuse to connect to a revoked device.
Short of finding a splitter or recorder that hasn't been revoked, or a setup that connects the VHS player directly to a recording device that ignores Macrovision, I don't know of another fix.
Of course, the revocation hypothesis is just conjecture on my part. It could be something else. -
Perhaps a factory reset would help ? Just an idea
*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
Can devices permanently permanently alter their allowed keys just via the HDMI ports though?
Did you try disconnecting all the HDMI devices from the reciever except the splitter and see if that makes a difference?
Did you change TVs? Changing that or something else could result in the devices negotiating a later HDMI revision which may cause the splitter to behave differently.
Lastly, I know dvd-recorders can sometimes change HDCP/copy protection on the output depending on content like if a dvd is copy-protected or not or if copy protection is detected on the selected analog input, maybe recievers do similar stuff. -
The only hardware change that I made was replacing my Tivo Edge with a FireTv Cube. Even though I don't use it at all for capturing video, I do recognize that this could have possibly caused the problem. I've tried taking it out of the equation, but it may have been too late since the problem still persists.Did you change TVs? Changing that or something else could result in the devices negotiating a later HDMI revision which may cause the splitter to behave differently.
The receiver is old, but I really can't rule anything out. I might have to take my entertainment center apart and try everything one device at a time.
It seems that the TV is still working fine. Only the capture cards seem to be affected. Is it possible that Windows 10 created new HDCP issues? -
I definitely seem to be in the minority on this forum as a Windows user. I hate Mac and Linux is too daunting for me. I'm in my late 40s now and have been a Windows user for most of those years. However, I wouldn't be surprised if Windows is the cause of my pain. I was really hoping that someone else was in a similar situation and knew how to solve it. I absolutely hate not knowing what the solution is. Even if the fix is expensive, I'd be happier than I am now.
are you getting any errors ?? see if anything here will help - https://www.avaccess.com/blogs/guides/hdcp-error-fix/
I'm not a fan of Windows but if something changed with the computer side it would likely be some driver thing by avermedia rather than anything by Microsoft.
Granted, as suggested in that link, it's possible some changes in the setup or connected devices resulted in the devices using e.g HDMI 2.x instead of 1.4 or similar causing the splitter to behave differently. If there was some key revocation on the keys on the splitter one would think it wouldn't output to the TV either, instead of just outputting with HDCP active. -
Thank you for the replies. I'm not getting any errors (except the HDCP recording prohibited message on my capture cards). The TV plays all media just fine. Do you think it's possible that adding the Fire Cube to the mix raised the HDCP requirement from 1.4 to 2.2? I dismissed that as a possibility since all the devices work on the TV.
I can't figure it out. I shelled out some serious cash for an HDFury Integral 2. Here's hoping...
Well, I'm not sure why, but even though I've been using the same setup for years, it suddenly stopped working and no other cheap HDCP stripping splitters seem to work anymore. I bit the bullet and shelled out the dough for the HDFury Integral 2. I had to update the firmware, but it works flawlessly now. My thanks to everyone who tried to help.
HDCP
By Baldrick in forum GlossaryReplies: 7Last Post: 4th Apr 2023, 11:34 -
HDMI splitter to bypass HDCP 2.2 for Full HD monitor
By TheCount_180 in forum ComputerReplies: 10Last Post: 30th May 2021, 19:56 -
Hdcp
By jjis in forum Capturing and VCRReplies: 1Last Post: 12th Oct 2020, 03:58 -
anyway to baypass HDCP on avermedia darkcrystal cd750?
By benhouli in forum Capturing and VCRReplies: 0Last Post: 30th Jan 2020, 14:13 -
Avermedia RECentral HDCP Protect Remove!!!
By afkomar in forum Capturing and VCRReplies: 1Last Post: 4th Jan 2020, 22:19
