Yesterday I spent a couple hours trying to figure out how to download some DRM protected streams.
I think I am doing everything right: find the MPD, copy the response, find the right pssh. Then look for the license url and copy the URL & cURL and put it in curlconvert to get the headers.
Someone explained it to me on Reddit, I gave him login info for the streaming site I was trying this on and he could get the video's keys using this method. But every time I tried I got a 401 unauthorized response, whatever I tried. I even tried to use the pssh, headers and license url he used to succesfully get the keys to the same stream.
I have tried incognito mode, incognito mode while connected to a wireguard VPN, another browser. Nothing seems to fix this issue.
I have tried a lot to try and isolate the issue, but I thought I could just best ask around on here.
Does anyone have a suspicion of what could cause this problem?
401 could mean several things, and it's difficult to give specific advice without more info. If the person that helped you could use these sites, it's not a geo problem. I'm guessing it's a header issue or an expired request.
Give site/headers/license either here or in pm and we'll be able to help you. -
maybe are the mpd expired example
i know one site, where is the mpd token to send a request only 1 min active, its a one time mpd so if you read that one time the mpd are not longer active, you can use that only by same IP.
so different ways. -
Hello bro key;kid please
AAAAXnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAD4SEHGDx6 uXSk/ojKAONnzsgpYaD3RodWRvbXVsdGltZWRpYSIRay1wbHVzLTEtN TBmcHNfU0QIAUjj3JWbBg==
K1 50
AAAAXnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAD4SEOe+mh uQ1E57gZZofvBLXWcaD3RodWRvbXVsdGltZWRpYSIRay1wbHVz LTItNTBmcHNfU0QIAUjj3JWbBg==
K2 50
AAAAWXBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADkSEDi5PI KBu0K9shwoi1VEdusaD3RodWRvbXVsdGltZWRpYSIMay1wbHVz LXBjX1NECAFI49yVmwY=
K2 bt
AAAAXHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADwSECnM0S/53UBMvl9jmuFwNN4aD3RodWRvbXVsdGltZWRpYSIPS19QTFVTX 05TX1NEX1NECAFI49yVmwY=
Life sd
AAAAXXBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAD0SEAHLbo iIvU8Xl8PyqkhD5D0aD3RodWRvbXVsdGltZWRpYSIQS19QTFVT X0tJRF9TRF9TRAgBSOPclZsG
Kidds sd
getwvkeys works but cdrm-project does not?
By Secondhand in forum Video Streaming DownloadingReplies: 11Last Post: 29th Apr 2023, 02:06 -
Help to use cdrm-project.com
By vidsrme in forum Video Streaming DownloadingReplies: 6Last Post: 26th Mar 2023, 06:11 -
getwvkeys.cc is not working
By jessezveneberg in forum Video Streaming DownloadingReplies: 29Last Post: 1st Jun 2022, 09:03 -
Windows 7: Sluggish & Slow To Respond
By Tom Saurus in forum ComputerReplies: 25Last Post: 4th Nov 2020, 08:44 -
DV 720p 59.94fps & Super 8 in same project?
By clashradio in forum EditingReplies: 5Last Post: 13th Sep 2019, 19:20
