Quick question:
If I were to convert a 25 fps Pal Svcd to a 29.97 fps Ntsc Vcd would the audio be outta sync? If so should i convert it to 23 fps instead? Or are there other solutions?
thanks
tks
are you sure you need to convert from PAL?Originally Posted by TKS
try putting a PAL sample SVCD on a disc and play it...you might not need to convert at all. my Pioneer standalone, and old crappy sylvania plays PAL SVCD's with no problems at all
edit: I guess I was reading too fast...I just noticed PAL SVCD-->NTSC VCD
you could try making it a PAL SVCD with VCD headers...search the forum for that--still might be able to play with no problem
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 12:13 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
audio video out of sync - somewhat
By beetlespin in forum AudioReplies: 2Last Post: 18th Mar 2010, 22:51 -
Audio out of sync with video
By J9 in forum MacReplies: 6Last Post: 24th Oct 2007, 08:28
