Hello, I'm new into this and I was wondering if someone could help me with how to download and decrypt live streams while the live is happening.
Do I download the video and once the live is done I decrypt? or do I actually have to download and decrypt while live is happening?.
What tools should I use for this?
Thank you!
Results 1 to 15 of 15
N_m3u8DL-RE works great for this. You can choose to download a section and then decrypt, or live mux-and-decrypt and play file immediately in VLC or whatever.
Just run 'N_m3u8DL-RE --help' for available commands. -
N_m3u8DL-RE can decrypt recording
Command Line:
N_m3u8DL-RE --save-name test "URL" --append-url-params --mp4-real-time-decryption --use-shaka-packager --live-real-time-merge --key kid:key -M format=mkv:muxer=mkvmerge -
sorry, maybe i do not understand your trouble ...
you can explain better what you mean ? -
for live stream, instead recording on disk i want to republish this live stream in hls format unencrypted but this tool are not appropriate.
You can stream with vlc. First use N_m3u8DL and save the two streams, video and audio. Then open in vlc:
Media / Stream / Add: decrypted (and still saving) video-stream
Click down on other options, check "play another media synchronously", click on Extra media / Browse, then Add the audio stream
Then stream. I didn't try it but should work. -
I am trying to live stream https://www.ctvnews.ca/live using mpv. I extracted its key, which seems to be constant. Trying to use
command and the video starts playing. However, shortly after, ffmpeg cannot receive the stream anymore, because "HTTP error 404 Forbidden". How can I avoid the error?mpv --demuxer-lavf-o=cenc_decryption_key=417edcac1b76db20cdd781c8ed58 0f28 https://live-news.video.9c9media.com/f/news/ctvnews/manifest.mpd
how to download and decrypt DRM protected video from youtube
By tania01 in forum Video Streaming DownloadingReplies: 5Last Post: 10th Feb 2023, 16:31 -
How I download this live streaming chanel of this page?
By diegori466 in forum Video Streaming DownloadingReplies: 23Last Post: 5th Sep 2022, 08:15 -
Download live streaming to cloud or some other server online?
By mondzg in forum Video Streaming DownloadingReplies: 0Last Post: 20th Jul 2022, 13:16 -
help, download this live streaming
By filipino in forum Video Streaming DownloadingReplies: 5Last Post: 23rd Jan 2022, 23:30 -
Can download and decrypt Video from Peacocktv, but not audio?
By delurker2021 in forum Video Streaming DownloadingReplies: 5Last Post: 22nd Aug 2021, 12:51
