I need to add two language audio tracks to several MKV files that already have their own original audio and several SRT subtitles.
I wrote this command line to run it in a batch file.
However, I only get a message like this in CMD.Code:@ECHO OFF chcp 65001 set mkvmerge=M:\FS\NF\mkvmerge.exe set input=M:\FS\NF\Original set AESP=M:\FS\NF\AESP set AKOR2=M:\FS\NF\AKOR2 set output=M:\FS\NF\New FOR %%f in ("%input%\*.mkv") DO ( "%mkvmerge%" --output ^"%output%\%%~nf.mkv^" --language 0:und --default-track 0:yes --language 1:kor --track-name ^"1:Coreano ^(NF HK version^)^" --default-track 1:yes --language 2:ara --language 3:ger --language 4:eng --language 5:fre --language 6:tur --language 7:vie --language 8:chi --track-name 8:Simplified --language 9:chi --track-name 9:Traditional ^"^(^" ^"%%f^" ^"^)^" --language 0:spa ^"^(^" ^"%AESP%\%%~nf_ESP.flac^" ^"^)^" --language 0:kor --track-name ^"0:Coreano ^(TV version^)^" ^"^(^" ^"%AKOR2%\%%~nf_KOR.flac^" ^"^)^" --track-order 0:0,0:1,0:2,0:3,0:4,0:5,0:6,0:7,0:8,0:9,1:0,2:0 ) PAUSE>NUL EXIT
I don't understand what the problem is. The paths are correct and even the filenames are simple and barely have a single space in the name, that's why I'm using quotes.Code:mkvmerge v75.0.0 ('Goliath') 32-bit Error: The file 'M:\FS\NF\AKOR2\EP 01_KOR.flac' could not be opened for reading: open file error.
Remove the first line to help you see the problem.
Although I removed the @ECHO OFF to see the full paths It took me a while to notice that there was a problem with the Korean language audio files after I tried muxing one language per session instead of both together.
Code:M:\FS\NF>set mkvmerge=M:\FS\NF\mkvmerge.exe M:\FS\NF>set input=M:\FS\NF\Original M:\FS\NF>set AESP=M:\FS\NF\AESP M:\FS\NF>set AKOR2=M:\FS\NF\AKOR2 M:\FS\NF>set output=M:\FS\NF\New M:\FS\NF>FOR %f in ("M:\FS\NF\Original\*.mkv") DO ("M:\FS\NF\mkvmerge.exe" --output "M:\FS\NF\New\%~nf.mkv" --language 0:und --default-track 0:yes --language 1:kor --track-name "1:Coreano (NF HK version)" --default-track 1:yes --language 2:ara --language 3:ger --language 4:eng --language 5:fre --language 6:tur --language 7:vie --language 8:chi --track-name 8:Simplified --language 9:chi --track-name 9:Traditional "(" "%f" ")" --language 0:spa "(" "M:\FS\NF\AESP\%~nf_ESP.flac" ")" --language 0:kor --track-name "0:Coreano (TV version)" "(" "M:\FS\NF\AKOR2\%~nf_KOR.flac" ")" --track-order 0:0,0:1,0:2,0:3,0:4,0:5,0:6,0:7,0:8,0:9,1:0,2:0 ) M:\FS\NF>("M:\FS\NF\mkvmerge.exe" --output "M:\FS\NF\New\EP 01.mkv" --language 0:und --default-track 0:yes --language 1:kor --track-name "1:Coreano (NF HK version)" --default-track 1:yes --language 2:ara --language 3:ger --language 4:eng --language 5:fre --language 6:tur --language 7:vie --language 8:chi --track-name 8:Simplified --language 9:chi --track-name 9:Traditional "(" "M:\FS\NF\Original\EP 01.mkv" ")" --language 0:spa "(" "M:\FS\NF\AESP\EP 01_ESP.flac" ")" --language 0:kor --track-name "0:Coreano (TV version)" "(" "M:\FS\NF\AKOR2\EP 01_KOR.flac" ")" --track-order 0:0,0:1,0:2,0:3,0:4,0:5,0:6,0:7,0:8,0:9,1:0,2:0 ) mkvmerge v75.0.0 ('Goliath') 32-bit Error: The file 'M:\FS\NF\AKOR2\EP 01_KOR.flac' could not be opened for reading: open file error.
Hello again. I want to come back to this thread because I have this problem again.
Unlike the previous case that was solved, now mkvmerge can open files despite having correctly assigned path variables and check that all files had the same names. I modified the batch file several times but still get the same error.
Code:set extVID=.mkv set extAUD=.flac set mkvmerge=%~dpn1mkvmerge.exe set invid=%~dp1.\MKV set inaud=%~dp1.\AUDFLAC set chap=%~dp1.\CHAPTERS set outvd=%~dp1.\NEW FOR %%f in ("%invid%\*%extVID%") DO ( "%mkvmerge%" --output ^"%outvd%\%%~nf%extVID%^" ^ --language 0:und ^ ^"^(^" ^"%%f^" ^"^)^" ^ --language 0:und ^ ^"^(^" ^"%inaud%\%%~nf%extAUD%^" ^"^)^" ^ --chapters ^"^(^" ^"%chap%\%%~nf.txt^" ^"^)^" ^ --track-order 0:0,1:0 )
Code:mkvmerge v75.0.0 ('Goliath') 32-bit Error: Could not open '(' for reading.
Code:set extVID=.mkv set extAUD=.flac set "ffmpeg=%~dpn1.\ffmpeg.exe" set entradaVID=%~dp1.\MKV set entradaAUD=%~dp1.\AUDFLAC set chapter=%~dp1.\CHAPTERS set salida=%~dp1.\NEW FOR %%V in (%entradaVID%\*%extVID%) do %ffmpeg% ^ -i "%%V" ^ -i "%entradaAUD%\%%~nV%extAUD%" ^ -strict experimental ^ -c:v copy ^ -c:a copy ^ "%salida%\%%~nV%extVID%"
"code":400,"error":true,"message" on http://getwvkeys.cc
By johnsonkiss in forum Video Streaming DownloadingReplies: 14Last Post: 25th Jul 2024, 21:45 -
Avidemux batch convert with "Muxer cannot open" error
By sansonet in forum Video ConversionReplies: 1Last Post: 12th May 2022, 05:35 -
Error: The file 'MKV3D_3D.264' could not be opened for reading: end of file
By xenomatic in forum Newbie / General discussionsReplies: 26Last Post: 31st Dec 2021, 18:11 -
Encore more and more unreliable as Win10 gets updated, "file is open..." ?
By Bansaw in forum Newbie / General discussionsReplies: 2Last Post: 13th Jun 2019, 15:05 -
Sudden onset of "Your input can't be opened:"
By stonecherub in forum Newbie / General discussionsReplies: 0Last Post: 17th Apr 2018, 14:01
