Results 1 to 28 of 28
  1. Hello, I am having a vpn problem in the series that I follow the series published abroad.
    Unfortunately, I have to show them in spain and mexico so that i can watch the series.
    Is there any browser plugin or solution for this?
    by the way i have nordvpn but there is something absurdly i don't understand why...
    I am not at home right now and when I log in to the internet from another house
    I cannot login to the nordvpn desktop application and download the plug-in via the internet browser and log in, but
    this time it does not matter which country I choose, it just gives the error that there is no connection.
    Site : https://www.nbc.com/sin-senos-si-hay-paraiso/video/catalina-ama-a-hernan/3067820
    I am not considering any purchase. Because I'm having trouble with nordvpn only at home for now.
    I'm looking for any browser addon or something I can bypass free vpn. Spain and Mexico especially
  2. Originally Posted by ProWo View Post
    You can use yt-dlp
    cmd closes automatically after opening
  3. yt-dlp work fine with nba site
    maybe you have old/wrong yt-dlp version. update from here: https://github.com/yt-dlp/yt-dlp/releases/tag/2023.03.04
    [Attachment 70366 - Click to enlarge]
  4. Originally Posted by mjking View Post
    You can use yt-dlp
    Preposterous!
    [Attachment 70367 - Click to enlarge]
    click click2
    If I/my posts ever helped you, and you want to give back, send me a private message!
  5. Originally Posted by [ss]vegeta View Post
    You can use yt-dlp
    Preposterous!
    [Attachment 70369 - Click to enlarge]
    I record a video , slow motion and i take picture. Look at that.. Cmd closes automatically after opening..
  6. Look at the answer. Don't reply just for the sake of commenting.
  7. I downloaded the program and it opens via cmd and closes automatically. I do not know the reason
    If anyone has any other suggestions, I'll listen.
  8. simply open cmd window from you have yt-dlp and run command like my post#4
    i think you don't run the right command
  9. Show the window completely.
    Dec 2020
    Croatia
    I think he doesn't understand what a command line program is, he just double clicks on the exe file and it doesn't open a window like handbrake so he's confused
    yt-dlp doesn't have a graphical interface, you need to open the terminal (command prompt/cmd or powershell in windows, terminal in linux/mac) and write a yt-dlp command into it
  11. Originally Posted by ampersand View Post
    [NBC] Extracting URL: https://www.nbc.com/los-miserables/video/daniel-enamorado/2817054
    [NBC] 2817054: Downloading JSON metadata
    [ThePlatform] Extracting URL: http://link.theplatform.com/s/NnzsPC/media/guid/2304991196/2817054?mbr=true&manifest=m...%22%3A+true%7D
    [ThePlatform] 2817054: Downloading SMIL data
    ERROR: [ThePlatform] 2817054: This content is not available in your location.
    You might want to use a VPN or a proxy server (with --proxy) to workaround.
    It gives an error because I am not in the same country. I don't understand why it says proxy. Do i need to add any code..???
    Dec 2021
    england
    You will need VPN to download video, it will not work if your outside from USA without vpn.
    im in UK, use vpn, download work fine
  13. Originally Posted by iamghost View Post
    I explained the issue at the beginning, why I can't use vpn..
    That's why I'm having problems, otherwise I have no problem with downloading if I can login with vpn.
    If you have any suggestions, I will listen.
  14. Unfortunately, you all missed something, if I was already in Spain, Mexico and America, it would not be a problem.
    I explained why I can't use nord vpn.
  15. I can't make out why using Nordvpn is an issue for you, but whatever. If that doesn't work for whatever reason, just use another service? Windscribe has free American servers. Proton as well. Google free proxies or put on fake glasses and a mustache.
  16. your issue it's really weird ...
    for me work fine only with yt-dlp https://nba_link without VPN and/or login
    and i'm outside to US territory
  17. You wrote what is not necessary, but did not write what is necessary.
    What country are you in?
    yt-dlp -U ?
  18. Anonymous
    Guest
  19. Let's do it like this then, I'm already having the nord vpn problem.
    So I'm looking for something that can bypass me temporarily
    It could be a browser add-on or it could be one of the free vpn services.
    Yes, windscribe did the job, but 10 gb with email confirmation is not enough for me.
    When I connected, there was a slow connection, I tried a couple of times.
    Thank you to everyone who commented...
  20. You just should solve your NordVPN problem.
    You write, you have no problems at home, right?
    And NVPN doesn't work if you are outside of your home, right? Says: "No connection".
    So there must be a difference beween your internet connection at your home and the internet connection outside.
    Maybe you use a cable LAN connection at home? And WLAN outside? It must be somehow different connections. The NordVPN app was installed at home, so is connected with the connection(-type) you use at home, thus it might be that it doesn't work outside.
    This is only guessing, but somewhere there has to be the problem.
    Dec 2020
    Croatia
    maybe try yt-dlp's "--geo-bypass" or "--geo-bypass-country US" options? they didn't work for me when I tried them but maybe the sites you're trying will work.
  22. Originally Posted by lomero View Post
    I did, but not work geo block
  23. i think your issue isn't geo block because, as already mentioned in my post#18, yt-dlp can download also without VPN (no need USA IP)
    also psiphon it's simply and free VPN and it work
    so, i think your issue is due to your web connection (maybe trough phone with hotspot?). some stuff block your connection. maybe also your internet provider
    another way is try to change DNS. try this one: https://www.sordum.org/7952/dns-jumper-v2-2/
  24. Originally Posted by lomero View Post
    my post #13 .. Psiphon Can't get past the geographic location barrier... The reason he works for you is just because it's not a problem for your country
  25. Finally fixed my problem with Vpn. no need for anything else..
    Thank you to everyone who helped out.
