I have been scratching my head over contradictory info on a subtitle stream or streams for some short videos from a DVD.
My usual tool is handbrake for any of these things and I do not use anything else.
Various troubleshooting tools either report a a subtitle file in sbtl format or don't see anything.
The recoded video files from DVD are in MP4. Various changes to MKV to use toolnix or some such have also failed.
What is the nature of the .sbtl format and how can it be viewed?
				Results 1 to 13 of 13
	You could try clever FFmpeg-GUI for extracting this Subtitle.
 Load your video, click main, click extract subtitle stream, select the stream and click extract.
	ffmpeg can extract and convert to SRT or SSA.
 https://forum.videohelp.com/threads/404981-Time-Text-subtitles
 https://forum.videohelp.com/threads/402515-Problem-with-extracting-tx3g-subtitles
	Thanks. I actually got this to work. Of the 7 short clips I just selected one and the response was "No Subtitle Found. " That may be the final word on it but I am going to check the DVD soon to see what plays on that. I can only test on an ASUS PC DVD player-- no standalone or bluray here.
	Op won't post anything,never does. I think,therefore i am a hamster.
	Here is the MediaInfo. There may be a clue on that.
 General
 Complete name : C:\Users\lon\Making War Horse a documentary featurette collection 2009 includes EN subs\Making War Horse Interview with Michael Morpurgo, author featurette.m4v
 Format : MPEG-4
 Format profile : Base Media / Version 2
 Codec ID : mp42 (isom/iso2/avc1/mp41)
 File size : 70.8 MiB
 Duration : 23 min 9 s
 Overall bit rate : 427 kb/s
 Frame rate : 29.970 FPS
 Encoded date : 2019-08-17 19:09:01 UTC
 Tagged date : 2019-08-17 19:09:01 UTC
 Writing application : HandBrake 1.2.2 2019022300
 Video
 Format : AVC
 Format profile : Main@L4
 Format settings : CABAC / 4 Ref Frames
 Format settings, CABAC : Yes
 Format settings, Reference frames : 4 frames
 Codec ID : avc1
 Bit rate : 322 kb/s
 Width : 720 pixels
 Height : 480 pixels
 Display aspect ratio : 16:9
 Original display aspect ratio : 16:9
 Frame rate mode : Constant
 Frame rate : 29.970 (30000/1001) FPS
 Standard : NTSC
 Color space : YUV
 Chroma subsampling : 4:2:0
 Bit depth : 8 bits
 Scan type : Progressive
 Bits/(Pixel*Frame) : 0.031
 Stream size : 53.4 MiB (75%)
 Writing library : x264 core 157 r2935 545de2f
 Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=300 / keyint_min=30 / scenecut=40 / intra_refresh=0 / rc_lookahead=30 / rc=crf / mbtree=1 / crf=25.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=20000 / vbv_bufsize=25000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
 Color range : Limited
 Color primaries : BT.601 NTSC
 Transfer characteristics : BT.709
 Matrix coefficients : BT.601
 Menus : 4
 Codec configuration box : avcC
 Audio
 Format : AAC LC
 Format/Info : Advanced Audio Codec Low Complexity
 Codec ID : mp4a-40-2
 Bit rate mode : Constant
 Bit rate : 96.0 kb/s
 Channel(s) : 2 channels
 Channel layout : L R
 Sampling rate : 48.0 kHz
 Frame rate : 46.875 FPS (1024 SPF)
 Compression mode : Lossy
 Stream size : 15.9 MiB (22%)
 Title : Stereo
 Language : English
 Default : Yes
 Alternate group : 1
 Menus : 4
 Text
 Format : Timed Text
 Muxing mode : sbtl
 Codec ID : tx3g
 Stream size : 2.00 Bytes (0%)
 Language : English
 Default : Yes
 Forced : No
 Alternate group : 3
 Count of events : 0
 Menus : 4
 Menu
 Format : Timed Text
 Codec ID : text
 Language : English
 Bit rate mode : CBR
 Menu For : 1,2,3
 00:00:00.000 : Chapter 1
 00:04:09.182 : Chapter 2
 00:08:10.957 : Chapter 3
 00:12:01.754 : Chapter 4
 00:16:08.634 : Chapter 5
 00:20:41.140 : Chapter 6
	The subtitle type is TX3G Timed Text. The usual for MP4/M4V/MOV containers.
 https://developer.apple.com/library/archive/documentation/QuickTime/QTFF/QTFFChap3/qtf...939-CH205-SW81
 But they appear to be empty.
	Oh boy.
 I admit I do not know how to read the fine points of MediaInfo's beyond bitrate and some simple things.
 This confirms my earlier suspicion that these sbtl entries were "ghost subs."
 Thanks for pointing out what I missed. I'll make mediainfos for all seven clips to see if they are the same.
  need some ideas on how to extract subtitle from streaming serviceBy naim2007 in forum Video Streaming DownloadingReplies: 5Last Post: 19th Aug 2022, 14:07
  Extract all subtitle with title from mkvBy iKron in forum SubtitleReplies: 1Last Post: 16th May 2022, 20:54
  Is there any difference between SRT and SBTL?By Hakunamatata67 in forum SubtitleReplies: 2Last Post: 29th Jan 2022, 10:55
  Can't extract webvtt subtitle with ffmpegBy [ss]vegeta in forum SubtitleReplies: 3Last Post: 18th Jun 2021, 18:20
  Hidden subtitle and how to extract them?By sh.nassau in forum SubtitleReplies: 0Last Post: 9th Feb 2020, 04:38
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
