I recently have been using Media Companion to organize my streaming movies content from a HDHomeRun tuner.
The Help files within it clearly state one of the default filters is Offline Movies, like the Watched and UnWatched filters. However, I cannot find it anywhere with in the application.
Does anyone use Media Companion to the extent they also know where this filter is available to select?
Hi there! I've used Media Companion before, so hopefully, I can assist you with your question. It sounds like you're trying to locate the Offline Movies filter in the application but can't seem to find it.
Based on what you've shared, it's possible that the filter may not be readily visible, or it may not have been enabled in your particular setup. One thing you could try is going into the application settings and checking if the filter is enabled or not.
If that doesn't work, I would suggest reaching out to the Media Companion community forums or support team for further assistance. They may be able to provide more specific guidance on how to locate the Offline Movies filter or offer additional solutions.
I hope this helps, and let me know if you have any other questions or concerns! -
I have read all of the online documentation I could find on it. And I see version 3.29 seems to show the option to filter by Offline Movies.
I've found a work-around. I created tags and associated them with my Offline Movies. I can search by tags and that accomplishes the goal.
Translation offline software
By carlmart in forum SubtitleReplies: 18Last Post: 23rd Aug 2023, 13:38 -
download videos for offline viewing
By alanonymous in forum Video Streaming DownloadingReplies: 3Last Post: 26th Jul 2021, 15:56 -
Video Downloaderhelper Companion App
By omaruko in forum Newbie / General discussionsReplies: 0Last Post: 14th Oct 2019, 21:32 -
Should I update Windows 7 if I only use it offline?
By wiseant in forum ComputerReplies: 12Last Post: 11th Sep 2018, 15:09 -
A Praire Home Companion archive is back!
By carszab in forum Video Streaming DownloadingReplies: 6Last Post: 3rd Jun 2018, 18:24
