  1. Hi all
    My OTT provider decided to postpone the web based player and provides OTT services only for Android devices . The provider keeps his own app for Android.
    During the past i was able to find the m3u8 links from chrome via developer options . The links were unprotected and downable.
    The question is if there is existing something to locate the links either from my android phone or Android TV device (I keep Nvidia shield TV and MI box).
    Googling a lot i have found solutions for Android based on web pages but nothing that can be traced from android application.
    Thanks a lot
  2. Thanks for this.
    I am forced to root my devices as these are working with root permissions.
    I will root an old oneplus2 that i keep and see if i will be able to sniff the m3u8 link.
  3. try using android studio on pc
  4. i tried but no luck with network tools. i could not find any m3u8 link etc
  5. Anonymous
    Guest
  6. Originally Posted by koukots View Post
    Thanks for this.
    You don't need root for apps Packet Capture or Debug Proxy or tPacketCapture or Nmap or NetMonster
  7. Im having the same problem
