    Apr 2023
    New Zealand
    I have successfully split a dual layer DVD into two using IfoEdit. I now have two directories with sizes 3.7G and 4.2G
    I am attempting to burn the results to single layer (4.7G) DVD.
    Both ImgTool on WinXP and DVD Image Utility on Mac (which use mkisofs) create ISO images with size 7.4G when attempting to process the 3.7G folder!
    What am I doing wrong? I'm expecting the ISO images to be almost the same size as the folder content.
    Also, can I skip the ISO creation and burn the folder content directly to DVD using Finder on Mac? (I understand that the DVD may not play on a DVD player, but I don't really understand why.)
    Cheers
    Matt
    canada
    As long as you created a proper authorized folder there's no need to create an iso,just burn the folder using the dvd burn method,not data.
  3. DECEASED
    Jun 2009
    Heaven
    WILD GUESS:
    you forgot to edit some .IFO(s) or/and some .VOB(s)
    — so that mkisofs "thinks" the VIDEO_TS folder should fit on a dual-layer disc and then it will pad the .ISO file with zeroes.
    "Programmers are human-shaped machines that transform alcohol into bugs."
