So I have a DVD-video of a concert.
In PgcDemux, I can rip the individual "songs" by using "Single Cell" and selecting the individual cells and process it. I have to do this 1 at a time.
BUT I'm hoping there's another tool that can do this automatically for me for all tracks.
Does that tool (freeware/shareware) exists? If yes, link/name please. Thank you!
EDIT1: I tried Audacity and it can't detect the songs properly since it's a concert. (no silence)
EDIT2: I want 1 file per chapter. PgcDemux can output 1 file for all chapters already.
Using AnyDVD plus DVD Decrypter, you can select the IFOs and drill down to select which titles, chaper(s) to rip (and if it contiguous it rips as one file) and also choose which streams to demux.
Then it is just a matter of remuxing V + A into the container type you want (at this point, I would suggest an ffmpeg GUI).
Scott -
I just tried it and the output are 2 WAVs files instead of multiple WAV files per chapter. Am I doing it wrong? Thanks
[Attachment 70243 - Click to enlarge]
[Attachment 70244 - Click to enlarge] -
It has only one stereo/2ch stream of audio in that graphic. Other than the possibility of a different title playlist, why do you think it should have multiple wav files?
Scott -
Try in 'file mode' that has an option to extract per item (cell ID) but it may include video which is not what you want ?
DVD Audio Extractor v6 0 2 is what I use for concert DVDs.
[Attachment 72611 - Click to enlarge] -
Looking at this again, I see in the graphic that what you probably mean was you wanted to select all chapters together and do the export in batch but have them be broken out individually on output rather than selecting them and exporting them individually. I can tell you that DVDDecrypter doesn't work that way. I am hopeful that bar72's example does.
[solved] VSDC Video Editor: Multiple audio tracks
By videomakeramateur in forum Newbie / General discussionsReplies: 1Last Post: 7th Apr 2023, 07:41 -
Download video with multiple audio tracks using yt-dlp
By Pavel_47 in forum Video Streaming DownloadingReplies: 12Last Post: 3rd Apr 2023, 07:25 -
Getting rid of multiple audio tracks, etc.
By Ethaliano in forum Video ConversionReplies: 2Last Post: 25th Jun 2021, 08:49 -
Identifying Video with Multiple Audio Tracks
By bigcarp22 in forum Newbie / General discussionsReplies: 2Last Post: 27th Aug 2020, 05:02 -
Video edition with multiple audio tracks.
By djdan in forum Newbie / General discussionsReplies: 0Last Post: 18th Nov 2019, 15:14
