Have 3 dvdrs (1 movie on each) where the video was made using a dvd recorder to copy vhs tapes. Unfortunately the creator stopped the recorder a couple times, then restarted the recorder after rewinding the vhs tape briefly. So each movie is in at least 3 segments. I wanted to make seamless edits for each movie, but the audio would lose sync slightly. I am using VideoRedo, using the "quickstream fix" option to save the segments first, then edit each, but the results were losing audio sync after joining them. I had to alter the segments (demux and add audio delay) so they would sync after joining. Worked for two of the movies, but last one won't work. And I've tried all three resync "Stream Parameter" options in VideoRedo. I know it's an old program, but this is an old tech problem. Maybe there's some other fix or program that would work?
Results 1 to 1 of 1
Problema con VideoRedo Tv Suite V6: Remove frame audio
By anet88 in forum EditingReplies: 1Last Post: 26th Jan 2023, 06:54 -
Which audio formats has better compression not losing quality ?
By Aug in forum Newbie / General discussionsReplies: 12Last Post: 2nd Aug 2022, 16:38 -
Losing Audio during DV Media Import from Camera
By Readheads in forum MacReplies: 6Last Post: 12th Dec 2019, 17:32 -
Poor man's Audio Sync Editing - looking for a good AVI splitter
By iosman in forum Newbie / General discussionsReplies: 3Last Post: 22nd Aug 2019, 13:54 -
Importing subtitles to Encore and losing sync
By sky captain in forum Authoring (DVD)Replies: 22Last Post: 11th Apr 2019, 17:38
