I have burned a couple of data DVD but Primo only limit around 4.4GB. Anyone know if we can overburn over 4.4 GB? (Using A04 and SuperMediaStore dvd generic)
Like everything else in this world, the size of a DVD depends on how you measure it. According to Disc manufacturers, 1 kilobyte = 1000 bytes and 1 megabyte = 1000 kilobytes. According to Microsoft and most of the rest of the IT industry, 1 kilobyte = 1024 bytes and 1 megabyte = 1024 of those kilobytes. So when Pioneer say the disc is 4.7 Gigabytes, that is using the disc manufacturers version of measurement (1k = 1000) but when measured by your pc, it displays its values using the 1k=1024 measurement method. Hence the discrepancy. (the actual capacity in bytes is the same BTW)
A DVD-r can contain approx 4.3Gigs of data (as measured by windows) and AFAIK overburning is not available.
Burning to Full Capacity of a DVD
By Agent 5 in forum MediaReplies: 6Last Post: 16th Apr 2012, 09:49 -
Simple question on DVD+R DL discs/Capacity
By alegator in forum MediaReplies: 12Last Post: 19th May 2011, 04:52 -
21.7GB on a DVD?
By sebrame in forum Authoring (DVD)Replies: 8Last Post: 1st Feb 2010, 15:56 -
Exact maximum capacity of DVD+R
By geohei in forum Authoring (DVD)Replies: 18Last Post: 21st Mar 2009, 09:23 -
Formatting a dvd-rw 4.7gb
By IOMEGA in forum Newbie / General discussionsReplies: 1Last Post: 13th Nov 2007, 14:56
