  1. Hi. I want to encode a 4K HDR10+ Movie to 1080p HDR10+ with StaxRip. but there is an issue.
    The color of output file is different with the source file.
    You can check it out with this link:
    Original File: https://fex.net/s/dbsxmpp
    Encoded File: https://fex.net/s/7tcypzd
    How I can do it without any change in the color?
    thanks
  2. How I can do it without any change in the color?
    HDR10+ Metadata itself should be resolution agnostic, but lowering the resolution will change the overall color perception.
    So, I don't think it's possible without any changes.
    (Sorry, no clue about StaxRip)
    As a side note:
    According to MediaInfo your source isn't HDR10+, it's HDR10:
    Video
    Format                         : HEVC
    Format/Info                    : High Efficiency Video Coding
    Format profile                 : Main 10@L5.1@High
    HDR format                     : SMPTE ST 2086, HDR10 compatible
    Codec ID                       : V_MPEGH/ISO/HEVC
    Duration                       : 6 s 167 ms
    Width                          : 3 840 pixels
    Height                         : 2 160 pixels
    Display aspect ratio           : 16:9
    Frame rate mode                : Constant
    Frame rate                     : 24.000 FPS
    Color space                    : YUV
    Chroma subsampling             : 4:2:0 (Type 2)
    Bit depth                      : 10 bits
    Default                        : Yes
    Forced                         : No
    Color range                    : Limited
    Color primaries                : BT.2020
    Transfer characteristics       : PQ
    Matrix coefficients            : BT.2020 non-constant
    Mastering display color primar : Display P3
    Mastering display luminance    : min: 0.0001 cd/m2, max: 1000 cd/m2
    Maximum Content Light Level    : 818 cd/m2
    Maximum Frame-Average Light Le : 554 cd/m2
    HDR-10+ normally would look like:
    Video
    Format                                   : HEVC
    HDR format                               : SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
    Codec ID                                 : hev1
    Codec ID/Info                            : High Efficiency Video Coding
    Duration                                 : 59 s 484 ms
    Source duration                          : 59 s 467 ms
    Bit rate                                 : 67.0 Mb/s
    Frame rate                               : 60.000 FPS
    Bit depth                                : 10 bits
    Bits/(Pixel*Frame)                       : 0.135
    Stream size                              : 475 MiB (95%)
    Source stream size                       : 498 MiB (100%)
    Mastering display color primaries        : Display P3
    Maximum Content Light Level              : 1000 cd/m2
    Maximum Frame-Average Light Level        : 400 cd/m2
    mdhd_Duration                            : 59483
    Codec configuration box                  : hvcC
  3. Originally Posted by Selur View Post
    As a side note:
    Video
    Format                         : HEVC
    Color space                    : YUV
    Bit depth                      : 10 bits
    Default                        : Yes
    Forced                         : No
    Video
    Format                                   : HEVC
    Codec ID                                 : hev1
    Bit depth                                : 10 bits
    oh. thanks for information about HDR10 and HDR10+.
    I have seen some encodes in trackers that have done this without any color change. for example this one: https://1337x.to/torrent/4393306/Gladiator-2000-Extended-1080p-BluRay-x265-HEVC-10bit-...7-1-afm72-QxR/
    I want to do something like this.
  4. No clue where the issue is, metadata seems fine. Don't know if StaxRip does any unwanted/needed tv/pc changes.
    Best ask in the StaxRip support thread. https://forum.videohelp.com/threads/369913-StaxRip
    Can't really say anything about differences of some illegal torrents.
  5. Originally Posted by Selur View Post
    OK. anyway thanks Selur for your help
