This is the video im trying to fix https://b3.thefileditch.ch/DIExbUgWVySLBCsXEbrm.avi
From what i have read in other post, i need the original source to fix it as this video frame type is "progressive", but still i wanted to ask, is there anything i could do? I will upscale and use frame interpolation later and wanted to clean it up a bit before, like dehalo, denoise, deblend... Point me to other post or useful pages where i can read and learn more, thanks![]()
I found a better source https://big.thefileditch.ch/b4/MWnClqjpFnGRakYVgIQw.mkv , playing around with avisynth i manged to fix it for most of the scenes with this
But for example in timestamp 1:52 there are still blended framesFFmpegSource2("Captain Tsubasa Ep 1 (JP DVDRemux).mkv",atrack=-1)
AssumeTFF()
QTGMC(preset="faster", EZDenoise=10.0, NoisePreset="Fast")
SRestore(mode=-1, omode=6, thresh=12, speed=-1, cache=10)
Doesn't solve the blends around 1:13 and 1:52, but using TFM(mode=7) instead of QTGMC might be faster.
Might be worth looking into exBlend (https://forum.doom9.org/showthread.php?t=175948).users currently on my ignore list: deadrats, Stears555, marcorocchini -
TFM(mode=7) works great, thanks a lot. Using srestore onmode 5 fixes those blends but it also mess up other scenes, ill keep testing.FFmpegSource2("Captain Tsubasa Ep 1 (JP DVDRemux)-00.00.00.000-00.02.25.433.mkv")
AssumeTFF()
TFM(mode=7)
srestore(omode=5,speed=9,thresh=22)
Those frames get blended like this aa ab ba bbLast edited by ArcoCapaz; 9th Apr 2023 at 08:12.
Given that the underlying cel animation is 8 fps in the section from about 1:52 to 1:55 I suspect those blends are intentional. You can get rid of the blends (and keep every original cel) by reducing the rate to 8 fps. But you'll need to dup back to 24 fps and somehow (manually?) detect those sections and paste them in.
Code:function TFMBob(clip v, int "pp", int "cthresh") { pp = default(pp, 6) cthresh=default(cthresh, 9) v.GetParity() ? Interleave(TFM(v, mode=1, field=1, pp=pp, cthresh=cthresh), TFM(v, mode=1, field=0, pp=pp, cthresh=cthresh)) : Interleave(TFM(v, field=0, pp=pp), TFM(v, field=1, pp=pp, cthresh=cthresh)) } Mpeg2Source("MWnClqjpFnGRakYVgIQw.d2v", CPU2="ooooxx", Info=3) TFMBob() p24 = SRestore(frate=24000.0/1001.0) p8 = p24.SRestore(frate=8000.0/1001.0).ChangeFPS(p24.framerate) ReplaceFramesSimple(p24, p8, Mappings="[2673 2772]") Trim(2612, 2785)Last edited by jagabo; 9th Apr 2023 at 10:53.
I see, thanks a lot for the help
, i have to think about manually editing those scenes as i plan to denoise, upscale... all the episodes.
DVD with what appears to be frame blending
By ThaKarra in forum DVD RippingReplies: 8Last Post: 4th Dec 2021, 10:34 -
Help needed restoring Anime to High Definition with comparison video file
By xonathan in forum Newbie / General discussionsReplies: 10Last Post: 17th Jun 2021, 16:11 -
Restoring a whole Anime movie using Neat Video
By xonathan in forum RestorationReplies: 4Last Post: 26th Apr 2021, 08:55 -
How to achieve frame-blending/motion blur?
By eko in forum Newbie / General discussionsReplies: 22Last Post: 29th Oct 2020, 09:36 -
Avisynth anime restoring
By BeyondTheEnergy in forum RestorationReplies: 11Last Post: 13th Aug 2018, 11:55
