Hi to all. I have an 23min mkv, with 720x576 res. The brightness is so dark, I cant see a thing. I tried to fix it with
some VLC settings, but gets worse than the original. Here is some pics:
[Attachment 70183 - Click to enlarge]
[Attachment 70184 - Click to enlarge]
[Attachment 70185 - Click to enlarge]
If it possible, I want to convert it without losing the quality and sound, but with more brightness and clean resolution.
The generic video info;
HTML Code:Duration 00:23:00 (1379.8 s) Container matroska Total tracks 2 Track nr. 1 video (V_MS/VFW/FOURCC) {und} Track nr. 2 audio (A_PCM/INT/LIT) {und} Muxing library Lavf56.31.102 Writing application Lavf56.31.102 Video track Codec ID V_MS/VFW/FOURCC Resolution 720 x 576 Display resolution 768 x 576 (pixels) Frame aspect ratio 5:4 = 1.25 Pixel aspect ratio 16:15 = 1.066667 Display aspect ratio 4:3 = 1.333333 Framerate 25 fps
Results 1 to 1 of 1
Brightness stabilization?
By killerteengohan in forum RestorationReplies: 7Last Post: 25th Jan 2023, 01:00 -
Bursts of brightness when using GREX XDIMAX.
By eeeeeeeee in forum Newbie / General discussionsReplies: 6Last Post: 1st Jan 2023, 22:21 -
Pana NV-HS960 TBC pumps brightness?
By prodarek in forum Capturing and VCRReplies: 19Last Post: 14th Feb 2022, 11:31 -
Converting MKV to MP4 Sync problem
By chang123 in forum Video ConversionReplies: 7Last Post: 7th Apr 2019, 18:41 -
Delay Problem with audio from dvd to mkv
By genesian in forum AudioReplies: 15Last Post: 16th Feb 2019, 13:52
