I would be grateful if the experts could advise what's going on with the attached DV AVI. I captured it back in 2006 from my ADVC-100 (those were the days!) and IIRC I didn't do anything to it after capture. Mediainfo is showing it is Interlaced BFF but it shows no jaggies and steps through the bob doubler filter in VDub as though it is Progressive.
Is this, in fact, a progressive file and therefore MediaInfo is incorrect?
Just a little curious about this clip.
Now my ADVC transfers say 'Canopus DV' or nothing (just DV) - these were done straight to the PC via WinDV.
Yours states 'Sony DV' which begs the question, if you can recall, the method/software you used. Maybe some version of Vegas which could have 'altered' the source. -
DB83, that is a good question and as I said, I don't recall doing anything with it after capture, with the exception of possibly trimming it with Scenalyzer.
I have checked a DV file I captured with the ADVC-100 just last year and it's codec is also DVSD (Sony); that was definitely untouched post-capture.
Yet another I have from 2006 is CDVC (Canopus).
The mere fact that it is Progressive means that I must have done something to it but I was a rank newby then, compared to what I know now. I vaguely remember dabbling with various DV codecs; I don't know how "the system" picks a particular DV codec for capture if you have more than one installed. I may have even captured it with VDub into Progressive if that's possible. I also remember having issues with DV Type 1 and 2 for Movie Edit Pro and using DVDate to fix that; maybe it flipped the codec.
I'm just thankful that they didn't turn out too badly, all things considered. -
Not necessarily. Film broadcast as PAL video is typically done by speeding the film from 24p to 25p and transmitting one field at a time (ie interlaced) at 50 fields per second. So pairs of fields come from the same film frame. It you capture with the same field order as the broadcast you restore the original film frames -- every frame of your cap will look progressive. If you capture with the opposite field order all you frames will show comb artifacts when there is motion because every video frame contains a field from a different film frame.
Code:4 film frames: 1 2 3 4 broadcast BFF: 1b 1t 2b 2t 3b 3t 4b 4t (a sequence of fields) captured BFF: 1b+1t 2b+2t 3b+3t 4b+4t (appears progressive, like the film source) captured TFF: 1t+2b 2t+3b 3t+4b 4t+5b (appears interlaced)
Code:interlaced frames: 1t+2b 2t+3b 3t+4b 4t+5b separate fields: 1t 2b 2t 3b 3t 4b 4t 5b discard first field: 1b 1t 2b 2t 3b 3t 4b 4t 5b 5t recombine fields: 1b+1t 2b+2t 3b+3t 4b+4t 5b+5t
Of course, I think you (or somebody) have said that before, Jagabo. Always learning. I should start writing this stuff down.
Help with combing
By shark_bloody in forum DVD RippingReplies: 20Last Post: 8th Aug 2022, 22:41 -
Combing in Deinterlaced Video
By unluckyfridays in forum Video ConversionReplies: 11Last Post: 12th Jul 2022, 11:07 -
Combing two VOB files
By EditingFan12 in forum Authoring (DVD)Replies: 6Last Post: 12th Apr 2022, 14:44 -
Fix combing in an already interlaced video.
By dabbdubb in forum Video ConversionReplies: 6Last Post: 3rd Feb 2021, 17:52 -
How to keep interlaced footage interlaced converting from AVI to MP4?
By kodec in forum Video ConversionReplies: 23Last Post: 1st Jul 2019, 09:36
