Hello,
I'm looking to test multiple compression algorithms for a specific need, and therefore need to have a RAW video for this.
the video needs to be FULL HD, 30 fps, 10-20 seconds in RAW.
Is it something that I can find somewhere to download, or should I create the video?
If I need to create it, which software to use? my need is mainly for space stuff, therefore I would put an image of the moon that I would move slowly across the screen, it's sufficient for what I'm looking to achieve.
Thank you in advance for your help!
I don't think there are any space videos but xiph has lots of uncompressed samples that are often used to evaluate codecs.
https://media.xiph.org/video/derf/ -
Here's a high quality video I made from a star field image and a moon image. I added some noise like you might get from a camera.
Alternatively you can use high resolution sequences (like 8..16k or higher) even lossy compressed and resize them to FHD to get "RAW" - should be quite close to real RAW - space agencies should have such footage
Cannot insert the video clip creation date on video output.
By ohuser in forum EditingReplies: 4Last Post: 6th Jan 2021, 02:38 -
join raw video files
By exekutive in forum Video ConversionReplies: 4Last Post: 22nd Nov 2020, 18:44 -
Inconsistent MDS file creation with ISO creation in ImgBurn
By Seeker47 in forum DVD RippingReplies: 3Last Post: 22nd Jun 2020, 04:47 -
how do i open a raw disc/ RAW format on a computer
By elm in forum DVB / IPTVReplies: 2Last Post: 9th Mar 2020, 18:33 -
Raw video for arm robbery
By Tim21090 in forum Video Streaming DownloadingReplies: 12Last Post: 29th Aug 2019, 13:15
