Hello,
I'm using XMedia Recode (V 3.5.7.5) for converting movie-files to mkv265. Unfortunalty I got a problem with converting forced subtitiles which should be shown automtically afterwards. Altough I've select "forced" and "default audio" within the subtitle-tab in XMEIDA, the subtitles are not shown automatically and have to select manually within the movie-player. Did anybody have an idea or the same effect? How can I fix it?
Thanks in advance! Mark
Need some more info,are these video being played on windows or through a tv media player or xbox or other output device?
What does a MediaInfo file say about your MKV file, is forced indicated? personally I would use MKVToolNix to make the MKV file or MakeMKV first followed by MKVToolNix to do any processing like setting defaults and force or adding or removing tracks.
Forced Subtitles (auto)
By JosephTocco in forum Newbie / General discussionsReplies: 3Last Post: 12th Mar 2025, 13:36 -
MKVToolNix - Forced display subtitles - still it needs to be selected
By vhwul62 in forum SubtitleReplies: 3Last Post: 4th Mar 2023, 07:30 -
How to add multiple subtitles into mkv as forced
By maverickluke in forum SubtitleReplies: 8Last Post: 25th Aug 2021, 04:22 -
Forced subtitles not being honoured by Quicktime or AppleTV in m4v
By lwoody7110 in forum MacReplies: 8Last Post: 23rd Feb 2021, 15:20 -
Insert Forced subtitles in Original subtitles (.srt)
By VideoOn in forum EditingReplies: 1Last Post: 12th Feb 2020, 02:43
