    Apr 2023
    Fort Mill, SC
    I see online, companies that will convert your old 8mm film to digital, upscale it to 1080
    And put it on a hard drive, and a DVD in SD.
    Does this actually work ? Or are they just ripping you off ?
    And when I say 8mm, I mean the ones on a real that goes through a projector.
    I would like them cleaned and hopfully dust and scratches / artifacts removed.
    Is there hopevfor having that done ? And maybe a suggestion of where ?
    The one I do see is mymovietransfer.com
  2. Banned
    Nov 2022
    You see them online, ergo this works.
    You can make your own scanner, there are many videos on YouTube about it, like this, for example: https://www.youtube.com/watch?v=yStZmqdWDLA
