  1. Hi there,
    is it possible to download the dash recordings in one file! from yallo.tv? Maybe there is a plugin or a standalone program?
  2. Get the mpd url and paste in N_m3u8
    Check if it's encrypted
  3. Originally Posted by mcjoe View Post
    I took a look at orf1 and here is what i found:
    MPD:
    https://zh2-1-dashenc-live.zahs.tv/HD_orf1/m_drm_widevine.mpd?z32=MF2WI2LPL5RW6ZDFMNZT2YLBMMWGKYLDGMTGG43JMQ6TCNZVGMZDONRSII2EKQJSGEYEGLJWGBCUMRJVGI2TCMZYIVDDOOKGEZSHE3J5NBSGG4B2FUYSY3DWNQ5DGJTNMF4HEYLUMU6TQMBQGATHG2LHHU4V6MZZHA3TMZJQHAZDOM3BHAZDGZTEGU2TCNZYGNSDEZJWGZRDQOJSEZ2GS3LFONUGSZTUHUYTAOBQGATHI5B5GETHK43FOJPWSZB5PFQWY3DPHI5DMNBSMRSTOZLEGY2GINJVHAZDMYRTMJRWMZRTGQTHMPJQ
    Lic Url:
    https://zh2-0-dashenc-live.zahs.tv/HD_orf1/l_drm_widevine?z32=MF2WI2LPL5RW6ZDFMNZT2YLBMMWGKYLDGMTGG43JMQ6TCNZVGMZDOMRWHBBUMOBXGI3TOLJXGEYEERRWHBATCQSGG4YTKRKDEZSHE3J5NBSGG4B2FUYSY3DWNQ5DGJTNMF4HEYLUMU6TQMBQGATHG2LHHU4V6MJZGY2WKZJRGMZTMZLEMQZGGMBXMM4TKZJVMIYTGY3EGMZTKYZREZ2GS3LFONUGSZTUHUYTAOBQGATHI5B5GETHK43FOJPWSZB5PFQWY3DPHI5DMNBSMRSTOZLEGY2GINJVHAZDMYRTMJRWMZRTGQTHMPJQ
    PSSH:
    AAAATHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAACwIARIgOTY2YmRjMWRiNjExZWM0YmM1YThmYThkYjIwN2Q3ODkaBnphdHRvbw==
    Keys:
    --key 1e3c5b860ffd159071bd435efd86ca08:c4eac99e54662e37e0458a7b4905d27c
    --key 966bdc1db611ec4bc5a8fa8db207d789:ce1900caef561173e6ec37678824ccf6
    then i recorded a part of the live stream (using N_m3u8DL-RE):
    N_m3u8DL-RE.exe -M format=mp4  --live-keep-segments false --live-real-time-merge --live-record-limit 00:00:20 --key 1e3c5b860ffd159071bd435efd86ca08:c4eac99e54662e37e0458a7b4905d27c --key 966bdc1db611ec4bc5a8fa8db207d789:ce1900caef561173e6ec37678824ccf6 "https://zh2-1-dashenc-live.zahs.tv/HD_orf1/m_drm_widevine.mpd?z32=MF2WI2LPL5RW6ZDFMNZT2YLBMMWGKYLDGMTGG43JMQ6TCNZVGMZDONRSII2EKQJSGEYEGLJWGBCUMRJVGI2TCMZYIVDDOOKGEZSHE3J5NBSGG4B2FUYSY3DWNQ5DGJTNMF4HEYLUMU6TQMBQGATHG2LHHU4V6MZZHA3TMZJQHAZDOM3BHAZDGZTEGU2TCNZYGNSDEZJWGZRDQOJSEZ2GS3LFONUGSZTUHUYTAOBQGATHI5B5GETHK43FOJPWSZB5PFQWY3DPHI5DMNBSMRSTOZLEGY2GINJVHAZDMYRTMJRWMZRTGQTHMPJQ" --save-name "ORF1"
    [Attachment 70206 - Click to enlarge]
    Regards
  4. Hello, first of all thank you "thej911" for the above reply.
    I have entered exactly your command line. Unfortunately the output does not work? What am I doing wrong
  5. Keys are wrong, try these instead
    --key 8c01da4f7a6ac578efd2952d1b46ef36:36e6df7642eb39a1a78f7188f06adefa
    --key eb491a672702b57d985992414e19355c:fd44db6438d0cdc79609d0ea258be1cf
  6. Thanks a lot. It worked How do I actually get the PSSH and the KEYS?
  7. Originally Posted by ElCap View Post
    I think the Keys keep changing , checked now and even found new keys
    Regards
