hi members , I have X2 Liteon iHAS324 DVD Drives in my PC and they have a feature where they rip slowly to reduce noise.
Anyways I read from googling you can disable it by holding eject for about 5 seconds. This works for me rarely.
Is some sort of app or method to disable it once and for all ?
I have low hopes but I'd be stoked if it could be done !
Have you tried: https://www.firmwarehq.com/Lite-On/iHAS324%2BB/files.html
it will at least have the firmware and then if it is not fast enough se Omnipatcher to patch the speeds.
Hard Drives Syncing Question: Same Copies Under Different Folders in Drives
By 75er in forum Newbie / General discussionsReplies: 14Last Post: 8th Sep 2022, 20:58 -
Low Light Video Noise Fix
By paulmolive in forum RestorationReplies: 38Last Post: 25th Sep 2020, 17:23 -
External hard drives hit a new low - $160 for 10TB!
By lingyi in forum ComputerReplies: 0Last Post: 9th Jun 2019, 18:33 -
what do you call external usb drives that are not flash drives?
By oduodui in forum Newbie / General discussionsReplies: 7Last Post: 26th Apr 2019, 13:21 -
Noise in Webcam But No Low-Light?
By dualdivx in forum Newbie / General discussionsReplies: 1Last Post: 14th Feb 2019, 13:57
