Results 1 to 19 of 19
  1. I've been using XMedia Recode for easily 5 or 6 years now to convert MP4 -> Webm, and right now I'm on a fresh Windows 10 installation, with a fresh install of the latest XMedia Recode, and for some reason it's shrinking my videos way down to postage-stamp sizes, with seemingly no way to make it NOT do that.
    The source video is 1920x1080, and for some reason, Xmedia Recode wants to output it as...176x144.
    Even if I go to Filters/Preview and manually change the width/height, it does nothing and refuses to go any higher than 176x144.
    What exactly is going wrong here? I'm confused as all hell since every time I've used XMedia Recode in the past, it worked just fine. No matter what I do, the program just utterly refuses to output anything higher than 176x144.
  2. All I could think to do is try another version of the program from a clean install. Hope that works.
  3. Yeah, that was one of the first things I tried. I tried using the Portable x64 version, and then the Portable x32 version, both of them did the same thing.
  4. Oh okay apparently you don't use "Custom" anymore, but instead have to choose HTML5 and then select the resolution from the drop-down list.
    Mar 2008
    Doesn't this button set the original size ?
  6. Nope. Tried clicking that button and it does nothing.
    Mar 2008
    That's interesting, you may have found a bug in the program or something about your source file.
    Have you tried it with any other sources?
    It behaves OK for me, you can see after I hit that 1920x800 box, the "resolution" info at the bottom shows the filter is now
    de-selected (the line through the eye)
  8. Nope, it's not the file. Tried older things that I have converted in the past and the same bug happens. Clicking the 1920x1080 button does nothing.
    Mar 2008
    The settings are in a file called xmediarecode.json, close the program and rename the file to xmediarecode.old
    The file may be in appdata/roaming/xmediarecode/
    or in the portable folder if you used that.
  10. Originally Posted by davexnet View Post
    Didn't work. Bug still happening.
    Mar 2008
    Is something crashing behind the scenes?
    Perhaps check the Windows event viewer, application and system logs at the corresponding timestamps.
    Also, if you haven't tried it already, download a fresh portable version and run it from a new folder
  12. Originally Posted by davexnet View Post
    Not that I can see, no. This is a fresh install of Windows 10 Pro 64-bit.
    Already did, multiple times. The one I'm running right now I just downloaded and it's running out of its own folder on the desktop.
    I'm just as stumped as you are. Been using this program for at least 5 or 6 years now, and now all of a sudden it's glitching out like this even on fresh installs.
    Mar 2008
    I haven't had your problem, but I did find a crash in my eventlog from earlier today. My PC is old, AMD FX CPU, could be a factor,
    using a different code path based on CPU capabilities
  14. Yeah, I don't see anything like that in Event Viewer, even scrolling down a good bit through System and Application.
  15. I add the same issue when upgrading. The issue appears to be the Profile setting. Change it to something higher (or unrestricted, depending on your needs).
    [Attachment 70152 - Click to enlarge]
  16. I already tried that
    ...but this time it's working? I set it to (unrestricted) and then the 1920 x 1080 button on the Filters/Preview tab actually worked.
    This shit's weird lmao
    At least I finally got it working, I guess.
    Mar 2008
    This 176x144 is a legit size enforced by some formats.
    ie. the "profile" or "format" chosen on the xmedia recode format tab.
    Are you really encoding xvid/divx mpeg-4 visual?
    What did you have for format/profile?
    What did you have for codec on the video tab ?
  18. Originally Posted by davexnet View Post
    No idea what that means. Just converting mp4 to webm.
    Mar 2008
    Thanks for the extra info. I can recreate it now, also happens with an older version.
    I notice if you momentarily select vp9 in the codec, the resolution is as it should be;
    change back to vp8 and it holds.
    This must be a bug in the code, just one of many.
    I might see if I can contact the author
