video file is 8bit YUV lossless MOV file 720x486 29.97fps interlaced. I want it to just resize to 720x480 without cropping.
Code:Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi") LoadPlugin("C:\Program Files (x86)\AVStoDVD\Lib\LeakKernelDeint.dll") Video = A2DVideoSource("H:\Video capture\MOVIE.mov", CacheFolder="S:\TEMP", VFR=true, FrameRate=29.97) Audio = A2DAudioSource("H:\Video capture\MOVIE.mov", CacheFolder="S:\TEMP") Video = Video.Crop(0,0,-Video.Width % 4,-Video.Height % 4).ConvertToYV12(interlaced=true) Video = Video.LeakKernelBob(0,7,false,false) Video = Video.AddBorders(0,24,0,26) Video = Video.Spline16Resize(720,480) Video = Video.SeparateFields().SelectEvery(4,0,3).Weave() Audio = Audio.Normalize() AudioDub(Video, Audio)
Results 1 to 15 of 15
Remove the Crop(....). But do you still want to AddBorders(...) before resizing?
AVSTODVD/HCENC failed to encode with this script
Code:Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi") LoadPlugin("C:\Program Files (x86)\AVStoDVD\Lib\LeakKernelDeint.dll") Video = A2DVideoSource("H:\Video capture\MOVIE.mov", CacheFolder="S:\TEMP", VFR=true, FrameRate=29.97) Audio = A2DAudioSource("H:\Video capture\MOVIE.mov", CacheFolder="S:\TEMP") Video = Video.ConvertToYV12(interlaced=true) Video = Video.LeakKernelBob(0,7,false,false) Video = Video.Spline16Resize(720,480) Video = Video.SeparateFields().SelectEvery(4,0,3).Weave() Audio = Audio.Normalize() AudioDub(Video, Audio) -
The crop modifies 486>484. The bob operation fails if the vertical size is not mod 4.
Probably best to leave it as is -
AVSTODVD/HCENC also failed to encode with this script. Is there a script I can use to encode 8bit YUV 720X486 to DVD without cropping or adding borders?
Code:Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi") Video = A2DVideoSource("H:\Video capture\HEROINE OF HELL.mov", CacheFolder="S:\TEMP", VFR=true, FrameRate=29.97) Audio = A2DAudioSource("H:\Video capture\HEROINE OF HELL.mov", CacheFolder="S:\TEMP") Video = Video.ConvertToYV12(interlaced=true) Video = Video.Spline36Resize(720,480) Audio = Audio.Normalize() AudioDub(Video, Audio) -
I guess you could add a border temporarily and then remove it after the bob.
Code:Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi") LoadPlugin("C:\Program Files (x86)\AVStoDVD\Lib\LeakKernelDeint.dll") Video = A2DVideoSource("H:\Video capture\MOVIE.mov", CacheFolder="S:\TEMP", VFR=true, FrameRate=29.97) Audio = A2DAudioSource("H:\Video capture\MOVIE.mov", CacheFolder="S:\TEMP") #Video = Video.Crop(0,0,-Video.Width % 4,-Video.Height % 4). video=video.ConvertToYV12(interlaced=true) video=video.addborders(0,2,0,0) ##### add temporarily Video = Video.LeakKernelBob(0,7,false,false) video=crop(video,0,2,-0,-0) ##### remove Video = Video.AddBorders(0,24,0,26) Video = Video.Spline16Resize(720,480) Video = Video.SeparateFields().SelectEvery(4,0,3).Weave() Audio = Audio.Normalize() AudioDub(Video, Audio) -
I add border to the bottom so it'll be 720x488 which is mod 4 but this script doesn't work
Code:Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi") LoadPlugin("C:\Program Files (x86)\AVStoDVD\Lib\LeakKernelDeint.dll") Video = A2DVideoSource("H:\Video capture\MOVIE.mov", CacheFolder="S:\TEMP", VFR=true, FrameRate=29.97) Audio = A2DAudioSource("H:\Video capture\MOVIE.mov", CacheFolder="S:\TEMP") Video = Video.ConvertToYV12(interlaced=true) Video = Video.AddBorders(0,0,0,2) Video = Video.LeakKernelBob(0,7,false,false) Video = Video.Crop(0,0,0,-2) Video = Video.Spline16Resize(720,480) Video = Video.SeparateFields().SelectEvery(4,0,3).Weave() Audio = Audio.Normalize() AudioDub(Video, Audio) -
But more than that, your script will produce poor video,Code:
Crop(0,0,-0,-2)
You cannot resize height of interlaced video without creating artifacts
Either use my script as-is or the A2D default -
This script doesn't work.
Code:Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi") LoadPlugin("C:\Program Files (x86)\AVStoDVD\Lib\LeakKernelDeint.dll") Video = A2DVideoSource("H:\Video capture\HEROINE OF HELL.mov", CacheFolder="S:\TEMP", VFR=true, FrameRate=29.97) Audio = A2DAudioSource("H:\Video capture\HEROINE OF HELL.mov", CacheFolder="S:\TEMP") Video = Video.ConvertToYV12(interlaced=true) Video = Video.AddBorders(0,0,0,2) Video = Video.LeakKernelBob(0,7,false,false) Video = Video.Crop(0,0,-0,-2) Video = Video.Spline16Resize(720,480) Video = Video.SeparateFields().SelectEvery(4,0,3).Weave() Audio = Audio.Normalize() AudioDub(Video, Audio)
How to crop an area from a video using AviSynth?
By ziptip in forum EditingReplies: 2Last Post: 3rd Jan 2022, 01:19 -
GUI for ffmpeg just to split (not crop, see EDIT)
By franc in forum Video ConversionReplies: 5Last Post: 5th May 2021, 10:38 -
Am I doing anything wrong with this avisynth script to crop & de-interlace?
By bergqvistjl in forum Video ConversionReplies: 3Last Post: 9th Nov 2020, 08:09 -
Avisynth crop caused weird Aspect Ratio
By pooksahib in forum Video ConversionReplies: 12Last Post: 11th Jun 2019, 15:42
