I compiled a dvd. A simple menu where there are links:
- play
- chapters
- audio
- subtitles
The dvd works perfectly on PC and Mac. Both the burned dvd and the folder format dvd. I have used both VLC (on PC and on Mac) and the virtual player on a Mac. Everything works perfectly. I am able to turn subtitles on and off via meni and enable either 2.0 or 5.1 track.
The problems come when I put the burned dvd inside two different players. An LG bluray and a Panasonic portable DVD player.
On the LG bluray player on the subtitles the spaces between each line are not respected. As if in editing the subtitles inside Architect I put them all next to each other without leaving a space.
On the Panasonic portable player, on the other hand, the subtitles are correctly separated, but I cannot activate them through the menu I created (and thus the links made in Architect).
I'm getting dumb. What kind of problems could there be? If it were a DVD construction problem I should see the same things on PC and instead this does not happen.
Can you help me with this? Has anyone had the same thing happen I am desperate!
Results 1 to 1 of 1
batch to remove blank lines in .txt
By marcorocchini in forum Newbie / General discussionsReplies: 3Last Post: 9th Aug 2022, 13:59 -
Small amount of blank space added to audio when converting with Handbreak
By Rowsinator in forum Newbie / General discussionsReplies: 9Last Post: 15th Sep 2021, 01:25 -
MOV Files Blank in Picasa, Blank Icons in Win Explorer
By Alwyn in forum Software PlayingReplies: 0Last Post: 8th Dec 2020, 01:58 -
Anyone know of a sub program that will break long lines into 3 lines?
By JeremyBrown in forum SubtitleReplies: 19Last Post: 13th Apr 2020, 19:03 -
Hot to move lines to next lines time?
By tevastevas in forum SubtitleReplies: 1Last Post: 23rd Aug 2019, 02:34
