Hi all
Other samll utilities that do the job are also welcome.
I would like to know if there is command available in realproducer
that allow me know the length of the real video(rm file)? i got bunch
of rm file to process - split rm file ,i need to know the length of
the video in order to split them evenly. and i got bored opening files
one by one.
realproducer 8.5 plus here.
thanks
Q.L
Just Another User
There gotta be a tools can extract the length of rm video for me from command line.... anybody ??
i found one myself. it has command like `rma -db file.rm` and dumps a lot info about the rm file including the duration. then you can filter it out. the utility has a lot more features , In some way it does perfectly jobs that realproducer doesn't . more info on
http://www.anime.com.ua/misc/alexey/rma.htmJust Another User
VirtualDub commandline - AVS to BMP/PNG/JPG
By wiseant in forum Video ConversionReplies: 0Last Post: 10th Mar 2012, 17:01 -
How do i AVS > WMV - the commandline way
By squadjot in forum Video ConversionReplies: 4Last Post: 27th Apr 2009, 07:59 -
what ffmpeg commandline should I use ?
By halsboss in forum Video ConversionReplies: 2Last Post: 3rd Apr 2008, 04:49 -
Commandline tool for background
By linkeboda in forum Authoring (DVD)Replies: 5Last Post: 12th Oct 2007, 08:09 -
VOB2MPG from a commandline?
By YoKnows in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 9th Jul 2007, 08:57
