Or vice versa
SVCD, VCD, Divx, there are no good guides available anyware, anyone want to oblige? :E
Is your coversion so you can convert SVCD NTSC to VCD PAL? if so I have a coversion guide that works but the ratio changes a little
o(-_-)o---------------------------------------o(-_-)o -
I know that professional NTSC film (or indeed cinema film) conversion to PAL is by speeding up the movie slightly from 24 to 25 frames per second. Thats why a movie on a PAL disc is usually 4 minutes shorter than the equivilant NTSC (or cinema) release.
Does your conversion process use the same trick?
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
Just a Thanks pal to ntsc guide.
By Fat Tony in forum Newbie / General discussionsReplies: 0Last Post: 9th Feb 2010, 13:03 -
Guide wrong? "Converting a PAL DVD to NTSC using CCE"
By OliverGrey in forum Video ConversionReplies: 2Last Post: 11th Jan 2009, 01:47 -
CCE guide for PAL to NTSC conversion
By alexs_eu in forum Video ConversionReplies: 9Last Post: 21st Jun 2008, 07:41 -
Need for NTSC DVD to PAL DVD guide
By Lure in forum Newbie / General discussionsReplies: 59Last Post: 17th Jan 2008, 14:43
