Thread: how to determine if video is DF or NDF
  1. #1
    Hello,
    is there any way to determine if a given 29,97 file is DF or not, besides checking burnt-in timecode? I'm looking for a fully automatic way of determining this, especially if there is no TC track embedded in the file metadata. How does media players (ex. Telestream Switch) know if a file is DF/NDF, so they can adjust presented timecode to match on-screen TC?
    Any help will be appreciated here
    Member Cornucopia's Avatar
    Posts
    15,968
    Re: how to determine if video is DF or NDF
    If there is no timecode track or visual burn-in, it doesn't matter. At all. 29.97 is 29.97.
    At that point, you could apply (as timecode track or visual burn-in) whichever is to your liking. DF is wall-clock-time-corrected but drops frame counts, NDF is contiguous but gets off-sync with wall clock time (not really noticeable until => 1hr.).
    it does matter for my workflow because I need to check if file is DF/NDF and provide this info to another production system, for subs creation process. I'm not supposed to add anything to the file, just grab the info and pass it to another team
    EDIT: additinally, if there is no BITC on the source file my tool is responsible for burning the timecode on screen, so I need to know if the file is DF or NDF, to properly apply colon or semicolon before frames counter
    Posts
    15,968
    What is the provenance of the file? Perhaps there might be residual metadata, depending on workflow, format. Check with Mediainfo. Post the text file here.
    Barring that, they are identical at this point, so pick one that matches your clients' setup and go with it.
    You say you are not supposed to add anything, but if it has no burn-in (bitc) to add some. Contradictory.
  1. Replies: 7
    Last Post: 17th Feb 2023, 14:32
  2. Determine Best Quality Video from Set?
    By joshua4 in forum Video Conversion
    Last Post: 7th May 2021, 02:19
  3. Replies: 4
    Last Post: 16th Oct 2019, 12:02
  4. How to determine how much is the desync between video/audio?
    By Alice in forum Newbie / General discussions
    Last Post: 2nd Apr 2019, 17:39
  5. Replies: 7
    Last Post: 28th Mar 2019, 12:56
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
