This could well have been an error I made accidentally with the wave form.
But the mysterious error is that as I go through dialog and make fine corrections, about 13 seconds is added to the
previous line which I then have to manually adjust downward on the timings. So the error has to be corrected in that step.
Is this automatic addition shown in a settings someplace? I cannot find it, so progress is slow at having to make a manual
correction each time. I have not seen it previously so it must be unique to this file and reloads along with it.
One thing I am going to try is resetting to default all SE settings at the settings tab. Perhaps that will solve the timing issues.
Even if I did a scratch install of the new version, it's possible something is saved in Profile. Anyway not solved yet.
Can I set manual starting time of all timestamps in Subtitle Edit?
By Hariachka in forum SubtitleReplies: 1Last Post: 21st Feb 2023, 14:25 -
Change minimum time between subs in Subtitle Edit
By loninappleton in forum SubtitleReplies: 15Last Post: 24th Jan 2023, 21:28 -
Change start time in Subtitle Edit
By loninappleton in forum SubtitleReplies: 3Last Post: 20th Jan 2023, 01:27 -
Subtitle Edit sub needs a new start time and recalculate from that point
By loninappleton in forum SubtitleReplies: 2Last Post: 24th Dec 2022, 00:59 -
Subtitle Edit time shifting issue
By vid100 in forum SubtitleReplies: 3Last Post: 7th May 2020, 19:20
