Hi all
I have a U-matic VO5850 deck and went to play a tape today and noticed the heads were pretty gummed up so I took the tape out and cleaned the heads with some Kim Wipes and isopropyl alcohol. Yes I made sure I spun the head the proper direction.
Anyway, stupid me, I should have let all the alcohol dry before I put the tape back in, however I did, and immediately I knew something was wrong, it threaded weird, so I immediately tried to eject the tape, and it got caught on one of the idler wheels, or one of the arms sticking up.
I was able to get the tape out and reeled back into the tape. Now when I put a tape it, the deck immediately goes into either rewind mode or fast forward(if the tape is already at the beginning) and will do that for about 10 seconds, and then stop. None of the other buttons work except eject. And eject only works after it's done its rewind/FF phase. If I try and press a button while it's rewinding or FFing, it'll stop while I hold the button down, but then immediately start back up.
I'm guessing maybe a sensor got knocked, or is dirty, or something. Anyone have any ideas?
I'm not familiar with umatic decks but i'd say either the mode switch is dirty or (more probably, as the unit was working before you put your hands in it
the LED sensor is somehow jammed/misplaced/ dirty (assuming there is one in umatic)
one video for you: https://www.youtube.com/watch?v=j-I7Bri8Nww*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
Turns out the right guide arm didn't properly return to its resting spot and wasn't grabbing the tape properly when I would reinsert a tape. Reseated it, and all is good now!
U-Matic capture project
By DopeNessMonster in forum Capturing and VCRReplies: 49Last Post: 5th Feb 2025, 19:36 -
Transfer Chain U Matic Help
By MikeMilligan in forum Capturing and VCRReplies: 8Last Post: 25th Apr 2023, 08:04 -
U-matic RM-690 remote control jack
By jonnybravo in forum Newbie / General discussionsReplies: 2Last Post: 22nd Feb 2021, 01:25 -
U-Matic won't play picture
By cynikalhedonist in forum Newbie / General discussionsReplies: 0Last Post: 25th Nov 2020, 14:48 -
U-matic captyre and sudio - video sync
By pharries in forum Capturing and VCRReplies: 7Last Post: 16th Jan 2019, 22:14
