I backed up a 4K UHD disc (decrypted) with Makemkv, and then burned it to a BD100 disc with ImgBurn. However, this disc can only be played on the computer with vlc media player, but not on the 4K UHD players of Sony and Panasonic. Does anyone know the reason?
Results 1 to 16 of 16
did you burn the full 100GB disc ?? most players will not read a 100GB burned disc.
see this thread - https://forum.videohelp.com/threads/388243-BluRay-Player-with-BDXL-Support -
For one thing, only pressed media is covered by the UHD Blu-ray spec. Burned media is also physically different from pressed media and the maximum bitrate supported by burned media is lower.
BD-XL has 3 or 4 layers but most UHD Blu-ray players can only read the first 2 layers (about 60-66 GB) if they read it at all. If you look at your UHD player's manual to see what kinds of burned media are listed as playable, BD-XL will probably not be listed. The supported burned media will all be single-layer or dual-layer.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Why do you want to "backup" a 4K disc? The original disc itself is a copy, do you think a burned disc will outlast a pressed disc? Don't waste your money on coasters, from the prices I'm seeing bxdl cost a pretty penny. UHD spec and BD-R/BDXL are quite different and not every player supports all 3, they're not required to.
For those of you who want to author your own 4K video for playback, the BD-R spec has been updated to accommodate 4K video on 25/50/100 GB discs, you should contact the manufacturer of player to find out if they've added the spec to the player. -
not sure how that was pertinent, since they weren't talking about DVD media prices, but BD-XL (which are going at ~$10/disc).
Scott -
Verbatim-branded BD-XL 100GB costs about $5.70 (US) per disc when purchased in a pack of 10 so they are not cheap. For comparison, Verbatim-branded BD-R DL 50GB costs about $3.16 (US) per disk, and their BD-R 25GB costs about $1 (US) per disk.
Use MakeMKV to make a MKV file of the main movie. Then get a media player and pop the file on a portable hdd. Voila!
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Make an ISO of the disc and play it from a hdd or usb stick. It's possible on the 4K UHD players of Sony and Panasonic they have an anti piracy rejection system much like Cinavia, altho that is not use on UHD discs. Also as mentioned
BD-XL has 3 or 4 layers but most UHD Blu-ray players can only read the first 2 layers (about 60-66 GB) if they read it at all. If you look at your UHD player's manual to see what kinds of burned media are listed as playable, BD-XL will probably not be listed. The supported burned media will all be single-layer or dual-layer.SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Maybe so, but it IS OFF TOPIC. You don't want to be know for threadjacking, do you?
Scott -
Backup Panasonic DMR DVDs
By SmurfRecorder in forum DVD & Blu-ray RecordersReplies: 0Last Post: 27th Jan 2023, 12:34 -
PotPlayer - UHD Disc playback - getting audio but no video!
By thinredline in forum Software PlayingReplies: 11Last Post: 17th Aug 2022, 15:46 -
Why is the JAWS 4K UHD streaming quality, better than my JAWS 4K UHD disc?
By ZackyDog in forum Video Streaming DownloadingReplies: 25Last Post: 28th Oct 2021, 04:23 -
UHD mkv to BD-R DL50GB - tool to shrink >50K UHD MKV to BD compliant BDMV?
By njweb in forum Blu-ray RippingReplies: 6Last Post: 5th Mar 2021, 03:07 -
Replacing audio track on a UHD Disc
By ernnnn in forum Authoring (Blu-ray)Replies: 1Last Post: 6th Feb 2021, 11:34
