Hello,
Recently I've become very interested in KVCDs, KSVCDs, & KDVDs. Yes, I'm very late to that party.Many threads I've read deal with TMPGEnc and various templates which needs an AVI source, but I have a lot of MKVs and MP4s and don't want to reencode to AVI only to reencode yet again to MPEG 1.
I've been using DVDStyler to make custom DVDs and they come out great. I really like how it lets you create menus, chapters, buttons, backgrounds, subtitles, ect.... I was wondering if there is any program that is similar, but to author KVCDs, KSVCDs, & KDVDs?
Also, is there a program similar to handbrake that can take an MKV source and allows cropping out borders to be saved as a KVCD, KSVCD, and/or KDVD compatible file?
I hope someone can help me with this. Thanks a bunch.
Well, what defines a so-called "K(wag) Video Disc" is just a low-bitrate/high-compression custom quantization matrix.
And you don't have to use only the "copyrighted"
one.
As long as it's only for learning purposes, I think it's O.K. to play around with the K-discs in 2023.
I have read somewhere that HCenc produces better quality at low bitrates than TMPGenc, so give it a try and see the difference (if any) with your own eyes.
One problem in HCenc: its maximum GOP size is only 36 frames. TMPGenc, on the other hand, does not have such limitation.
Other MPEG-2 encoders which allow very-long GOPs are x262 and mpeg2enc (part of the MJPEGtools package).
P.S.:
Not "similar" to DVDstyler, but DVD-lab Pro does accept "non-compliant" GOP sizes and "non-compliant" resolutions (frame dimensions).Last edited by El Heggunte; 17th Mar 2023 at 20:13. Reason: ooops :-/
"Programmers are human-shaped machines that transform alcohol into bugs." -
You can use DVDPatcher to patch the first resolution header to a resolution allowed on DVD, to trick the authoring software.
HCenc produces better results at any watchable bitrates compared to TMPGenc 2.5(ish). If you read somewhere that TMPGenc 2.5 is good for low bitrates, it was probably written ~20 years ago, during the (X)VCD and (X)SVCD era, when there weren't many alternatives. -
Ah ok, I see.
LOL
I didn't see it mentioned anywhere, but I'll definitely give it a try.
Would using these tools eliminate the need for the authoring program to reencode the video for the KDVD?
Wow, I would wouldn't have guessed based on the name. But it looks like it's no longer developed. I'll see if it can somehow still be purchased.
Thanks a bunch.
I'm a bit lost on this one. Why would one need to do this?
That is one of the problems I've had while researching for this info, it's either outdated, contains broken links, or a message thread has an attachment that can't be downloaded if you're not logged in, but I can't log in because the forum is usually archived and I don't have a account not will it will allow me to register one.
I'll take a look at those.
Many thanks guys.
If you are using a DVD authoring software which rejects streams with a non-compliant resolution (from what I remember, "KDVD" for example may use a width of 528, which is not a legal width for DVD), you can use DVDPatcher to fool the authoring software into thinking the video actually has a compliant width (such as 720).
Whether you need this or not depends on how strict your authoring software is, and it only applies to authoring DVDs, not for (X)VCDs and (X)SVCDs. Also keep in mind this creates an off-standard disc which may not play correctly in every hardware player.
Although I would highly recommend you do go for DVD as a medium, not CDs. There is really no point in using CDs for video, too many restrictions. -
I see.
I was under the impression that a KDVD could be in a variety of resolutions like an XVCD. But you're right, DVD has only four resolutions that are considered legal from what I read.
Hmmm. Good to know. I think I'll stay away from that width of 528. I would at least like to stay around 704.
Yes, that's true but for shorter video projects (an hour or less) I like to use CDs as cDVDs in DVDStyler. I give these out to people when I want to show them something. Over here stores still sells lots of CD-Rs, much more than DVD-Rs.
Thank you.
DVDStyler Failed
By reign256 in forum Newbie / General discussionsReplies: 0Last Post: 15th Jan 2021, 21:12 -
DVD-Audio burning program - lossless & dual layer
By efc1978 in forum Newbie / General discussionsReplies: 23Last Post: 8th Feb 2020, 08:12 -
Need a program that lets you BOTH split clips & name them before export...
By MishaPrada in forum EditingReplies: 5Last Post: 12th Apr 2019, 10:58 -
whats the best program for edit MENU, VIDEO & AUDIO DVD?
By enable in forum Authoring (DVD)Replies: 8Last Post: 26th Oct 2018, 14:43 -
DVDStyler
By Sirbu in forum Authoring (DVD)Replies: 5Last Post: 15th May 2018, 12:55
