Is there a precompiled way of loading avisynth on a debian linux system?
Results 1 to 13 of 13
Assuming you are on Debian 11 (Bullseye), see: https://debian.pkgs.org/11/multimedia-main-amd64/avisynth+_3.7.0-dmo4_amd64.deb.html
But note, this is only Avisynth, you are still missing all the external filters with this, so this is only a start.
Cu SelurLast edited by Selur; 17th Mar 2023 at 02:06.
users currently on my ignore list: deadrats, Stears555, marcorocchini -
I've never used it, but Vapoursynth is supposed to be Avisynth for Linux https://www.vapoursynth.com/
Afaik, there is no one offering precompiled Avisynth filters for Debian systems. (only filter I saw was ffms2)
So if you want to use Avisynth on Linux, be aware that:
a. you will need to compile most of the filters yourself
b. some of the filters are closed source so you can't compile them
c. some of the filters will not compile on Linux since there code as it is atm. only supports Windows
-> if you have no experience with compiling stuff, forget using Avisynth natively on Linux atm.
If you have to use Avisynth on Linux, your best (in my experience unstable) option is to use Wine and your Windows Avisynth tools.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
I run avisynth 32bit in wine on debian bookworm no problem. Also hcenc, avspmod tmpeg 2.5, dgindex etc no problem. Just setup wine then run the avisynth installer. The plugins folder will be /home/(username)/.wine/drive_c/Program Files/avisynth/plugins
The debian wiki has how to setup wine and enable 32bit. If you just want avisynth piped to a native Linux enoder like ffmpeg avs2yuv works as well.
Also used it on debian Jessie, and bullseye no problemif all else fails read the manual
avisynth+ now natively supported in ubuntu linux
By oduodui in forum LinuxReplies: 1Last Post: 25th Apr 2023, 10:42 -
moving from avisynth to avisynth+
By pooksahib in forum Video ConversionReplies: 9Last Post: 23rd Feb 2023, 08:37 -
[LINUX] can ffmpeg (or any othe linux command) genere an ANIMATED waveform
By Jintor_Universe in forum ProgrammingReplies: 5Last Post: 28th Oct 2021, 19:29 -
DVDFab for Linux
By nypaulie in forum LinuxReplies: 3Last Post: 11th Jan 2020, 17:47 -
linux whine
By aedipuss in forum LinuxReplies: 6Last Post: 7th Nov 2019, 12:12
